12 Replies Latest reply on Mar 21, 2013 4:20 AM by Cenchen
    unused paragraph character and swatches
    Bhatt, Manish
      Hi All
      I have create a new script Deleted unused paragraph, unused charaterstyle and unused swatches but they have not run in batch please check my script and update me what is incorrect on this script please help me
      //Create by Manish Bhatt (DMD)
      try{
                 // Ask for the input and output folder (or hardcode define them if you want)
                 inFolderName= Folder.selectDialog ("Input Folder:");
                 // inFolderName = "/ID Files";
                 if (inFolderName != null )
                  var idFileFolder = new Folder(inFolderName);
                  // If you need the script to create the folder, do this
                  //var expFileFolder = new Folder(outFolderName);
                  //expFileFolder.create();
                  var dir;
                  dir = idFileFolder.getFiles();
                  //for each sub folder
      for(i=0;i<=dir.length-1;i++)
                  var idFileFolder1=new Folder(dir[i]);
                  // get the list of files that are InDesign files
                  var files = idFileFolder1.getFiles("*.indd");
                 for(myCounter = 0; myCounter < files.length; myCounter++)
                  app.open(File(files[myCounter]), true);
                  var myDoc=app.activeDocument;
                  with ( myDocument )
                  //file set in Bleed options.
      var myIndesignDoc=app.activeDocument;
      var myParStyles = myIndesignDoc.paragraphStyles;
      var myCharStyles = myIndesignDoc.characterStyles;
      var myUnusedSwatches = myIndesignDoc.unusedSwatches;
      for (var j=myIndesignDoc.unusedSwatches.length; j > 0; j--){
        myIndesignDoc.unusedSwatches[j-1].remove();
      for (j = myParStyles.length-1; j >= 2; j-- ) {
         removeUnusedParaStyle(myParStyles[j]);
      for (i = myCharStyles.length-1; i >= 1; i-- ) {
         removeUnusedCharStyle(myCharStyles[i]);
      function removeUnusedParaStyle(myPaStyle) {
         app.findTextPreferences = NothingEnum.nothing;
         app.changeTextPreferences = NothingEnum.nothing;
         app.findTextPreferences.appliedParagraphStyle = myPaStyle;
         var myFoundStyles = myIndesignDoc.findText();
            if (myFoundStyles == 0) {
               myPaStyle.remove();
      function removeUnusedCharStyle(myChStyle) {
         app.findTextPreferences.appliedCharacterStyle = myChStyle;
               myChStyle.remove();
                  app.activeDocument.save(File(files[myCounter]));
                  app.activeDocument.close();
                  //Note that you could also use:
      catch ( err ) {
      // Silently fail
      alert("All Indesign file remove para and character style");
        • 1. Re: unused paragraph character and swatches
          Cenchen Level 2
          Use this,
          try{
                      var files;
                      files = idFileFolder.getFiles("*.indd");
                      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
                                       myPaStyle.remove();
                                       myChStyle.remove();
          catch ( err ) {
          // Silently fail
          • 2. Re: unused paragraph character and swatches
            Jump_Over Level 5
            my suggestion of changes:
            1. #target indesign
            if InDesign is not opened when you start script - it won't do nothing;
            2. var idFileFolder = new Folder(inFolderName);
            If there is some .indd file out of subfolder - script will exclude it.
            3. app.open(File(files[myCounter]), true);
            Files is an array of files so app.open(files[myCounter],true) is good enough.
            4. var myParStyles = myIndesignDoc.paragraphStyles;
            If there are some styleGroups in your doc - will be excluded; use myIndesignDoc.allParagraphStyles;
            charStyles is same story.
            5. with ( myDocument )
            This line has to be removed (no var defined)
            6. app.activeDocument.save(File(files[myCounter]));
            app.activeDocument.save() is good enough, or even
            app.activeDocument.close(SaveOptions.YES);
            rgds
            Jarek
            • 3. Re: unused paragraph character and swatches
              Bhatt, Manish Level 1
              its not working please check again
              • 4. Re: unused paragraph character and swatches
                Hi
                There some error on this script
                • 5. Re: unused paragraph character and swatches
                  They have only run to seleted folder i have run to batches please again check and send me batch script
                  • 6. Re: unused paragraph character and swatches
                    Cenchen Level 2
                               Did u check with mine, which was working fine for me....
                    • 7. Re: unused paragraph character and swatches
                      Cenchen Level 2
                      And, you shown that error msg was expected ")".
                      Use this line instead of that  app.open(File(files[myCounter]), true);
                      • 8. Re: unused paragraph character and swatches
                        Cenchen Level 2
                        The below code will run selected folder and also the sub folders.
                        try{
                                            var f = idFileFolder.getFiles();
                                            for(var x=0;x<f.length;x++)
                                                   if(f[x].toString().match("\.indd$","i"))
                                                       unUsed(f[x]);
                                                    else
                                                        subFolder(f[x])
                                            function subFolder(SF)
                                                    var files;
                                                    files = SF.getFiles("*.indd");
                                                            unUsed(files[myCounter]);
                                                return true;
                        catch ( err ) {
                        // Silently fail
                        function unUsed(inddFile)
                                    app.open(File(inddFile), true);
                                                     myPaStyle.remove();
                                                     myChStyle.remove();
                                           app.activeDocument.save(File(inddFile));
                            return true;
                        • 9. Re: unused paragraph character and swatches
                          No it not working on batches
                          • 11. Re: unused paragraph character and swatches
                            This script not run in batches please make sure i want only run in batches (Lot of file open and remove all unused swatches and paragarh and character style). Not in single file
                            • 12. Re: unused paragraph character and swatches
                              Cenchen Level 2
                              that script is running very well in batch process at my end( windows, InDesign CS5.5).
