2 Replies Latest reply on Mar 22, 2013 1:00 AM by 4500 Times
    Jittery output from Premiere Pro
    4500 Times
      Hi.
      I am creating wmv files from sets (say 300 frames) of still renders from 3DS Max.  I originally created JPEG frames.  The resulting wmv files were jittery/stuttery when played back in VCL or Windows Media player.  I tried creating better quality TIFF files but the resulting wmv files were still jittery.
      Has anyone any idea what could be causing this and what settings I could try.  I have been through the obvious Bitrates/Codecs etc.
      I am using Premiere Pro CS6 on 64 bit Windows 7 (SP1) Intel Quad Xeon 3.6 with 24Gb RAM.  My graphic card is an  NVidia Quadro 5000.
      Terry
        • 1. Re: Jittery output from Premiere Pro
          joe bloe premiere Level 5
          The file format of your rendered max sequence will have
          no bearing on the smoothness of playback of your exported video.
          You should render your max sequences to a high quality, full resolution
          uncompressed image format.
          What is the intended frame rate of your max render?
          What is the frame rate of your Premiere sequence?
          What is the target frame rate of your exported .wmv?
          • 2. Re: Jittery output from Premiere Pro
            4500 Times Level 1
            Hi Joe.
            Many thanks.  It was down to the fps.  I couldn't find where the setting was to change the fps for the sequence.  I eventually found it and also created a custom sequence with 30 fps.  My fps from Max is 30 but when I first imported into Premier it came in as 25 (not sure why?).  I also originally set up a standard widescreen sequence that was 29.97 fps.  Now everything is at 30 fps it seems much better.
            The playback is not perfectly smooth but much more acceptable.  Are there any other settings when I export from Premiere that will help to make it smoother (e.g. bitrate/max render quality etc?) (I am completely new to Premier Pro).
            When these are complete they are going into a Powerpoint.  I find that no matter how good the wmv files are there is still some "jerkiness" in playback in PP.  Any tips on this?
            Many thanks,
            Terry
