This content has been marked as final.
Show 2 replies
1. Re: Espace insécable/nonbreaking space and nonbreaking space (hunting fix)
Philippe Ruelle Mar 22, 2013 2:24 AM (in response to Philippe Ruelle)Ok
the problem is justification option -> Composer -> Adobe Single-line Composer universal, if I put this option on something else this function!Ok
Le problème est option de justification -> Compositeur -> Compositeur ligne simple universel Adobe, si je met cette option sur autre chose cela fonction!
2. Re: Espace insécable/nonbreaking space and nonbreaking space (hunting fix)
P Spier Mar 22, 2013 4:01 AM (in response to Philippe Ruelle)Can you show us some screen shots?
Are all of your spaces fixed-width or are you using a lot of non-breaking spaces? When you do that you don't leave much room for ID to do space adjustments for justified text, and the single line composeer makes it worse because ID can no longer consider all of the lines in your paragraph together.
