This content has been marked as final.
Show 3 replies
1. Re: Gaps between divs
Newsgroup_User Nov 5, 2007 9:31 AM (in response to BruceCSI2)BruceCSI2 wrote:
> I set up this demo page, http://www.mistchild.com/gruen/index.htm and there are
> gaps between divs when viewed in IE, but not Opera or FF. The weird thing is,
> they show up between the themepic div and the nav div, and between the content
> div and bottom div, but not between the nav div and the content div. I've set
> top margins of 0 for all divs in my stylesheet.
> Can anyone help me figure this one out?
> Thanks
Before I take a closer look see if this gets rid of the gaps:
img {
display: block;
2. Re: Gaps between divs
BruceCSI2 Nov 5, 2007 10:30 AM (in response to BruceCSI2)I'll have to try that later. I'm not at a computer where I can try that right now. -
3. Re: Gaps between divs
Newsgroup_User Nov 5, 2007 11:36 AM (in response to BruceCSI2)"BruceCSI2" <webforumsuser@macromedia.com> wrote in message
news:fgnj8t$pan$1@forums.macromedia.com...
>are
> is,
> content
> set
Your construct is really "weird", try this:
#nav,#content,#bottom{float:none}
img{vertical-align:bottom}
If that fixes your problem, then you can simply *remove* the float
declarations from your sheet.
As a side note, you should try to keep things as simple as possible. I'm
sure you can safely remove "position:relative" from many rules. Also, there
is no need to set a width on DIVs that are not floats (their natural
behavior is to fill the the parent container).
HTH,
Thierry
Articles and Tutorials: http://www.TJKDesign.com/go/?0
http://www.divahtml.com/products/scripts_dreamweaver_extensions.php
- divaGPS - Add "you are here" highlighting to virtually any menu
- divaFAQ - Create FAQ pages that toggle (show/hide) the answers
- divaPOP - Easy, clean, standards-compliant popup windows.
