2 Replies Latest reply on Mar 22, 2013 9:51 AM by ParreLaws
    Text Changing?
    ParreLaws Level 1
      Is there a way in InDesign to mark and/or link text so when you change it in one place it changes in all other places in the document where the text is marked in that manner? Example: I have a brochure that the company names changes.
        • 1. Re: Text Changing?
          Eugene Tyson Adobe Community Professional & MVP
          You can use a Text Variable
          Type>Text Variable>Define
          Use a custom one, then use Insert Variable in the text.
          You place a linked story (this is text frame only and not middle of paragraph)
          Select the Frame and choose Edit>Place Linked Story
          The text now appears as link in the Links Panel - and if you update the first instance it asks you to update all instances
          You could use Find Change to do it
          Simply select the company name and copy it
          Edit>Find/Change
          Find
          <PASTE>
          Change to
          <insert new company>
          Change All
          • 2. Re: Text Changing?
            ParreLaws Level 1
            Thank you every much, the Text Variable/linked story is just what I looking.
