1 Reply Latest reply on Mar 22, 2013 1:19 PM by George_Johnson
    Required Fields
    1098Brianna
      How do I make a field required ONLY when a previous field has been filled in. Example: If you fill in blank 1, then you have to fill in blank 2
        • 1. Re: Required Fields
          George_Johnson MVP & Adobe Community Professional
          If the second field is a text field, you could use the following as its custom calculation script:
          // Set this field to required if "text1" is not blank
          event.target.required = getField("text1").valueAsString;
          Replace "text1" with the actual name of the field.
