• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Once site is up, can clients make changes?
Engaged ,
Mar 24, 2013 Mar 24, 2013
I'm wondering once Muse is set up and hosted with BC, can a client go in and edit -- as they can do with Word Press?
I see there are some changes in Admin panel,  but I don't understand it.  I've read quite a bit online but am missing this aspect.
Thanks!
TOPICS
Newbie Corner
Views
715
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Yes but there is an option you need to turn on in th esettings on the BC site and you wont be able to make any more changes in Muse.
Muse is a basic web builder tool, So it uploads all the site every time you mkae a change.
IF you want to build a more rich and controlled site using the BC CMS you should look to build the site using coding software such as Dreamweaver or other applications like Coda (mac) or Sublime Text 2 etc.
Votes
Translate
Translate
Report
Report
Engaged ,
Hi Liam, thanks!
Does that mean if I use DW the client will be able to make changes in BC Admin panel -- and I can also jump back in with DW and update at a later time?
I do use DW, as a designer I find the earleir DW versions were easier so I find myself back and forth between MU and DW.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mar 25, 2013 Mar 25, 2013
Hi Anita
Yes, your client would be able to access admin section of the site and make changes.
You can create site from Muse or DW , after publishing the site , adding the users as admin to the site will allow them to login to BC backend and make changes.
You can update your site from Muse or DW while working on the site to make changes.
Regards,
Sanjit
Votes
Translate
Translate
Report
Report
LEGEND ,
Sanjit, that is not exactly true as you should know with regards to Muse. Muse does not work quite the same.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mar 26, 2013 Mar 26, 2013
LATEST
Hey Liam
I was referring to adding users at BC end and allowing admin access , you are correct as we need to enable the setting under my details.
If that is the case then admin user who has access to Muse will not be able to update the site.
Regards,
Sanjit
Votes
Translate
Translate
Report
Report
