1 Reply Latest reply on Nov 1, 2007 2:55 PM by Gregory Lafrance
    Using flex for thik client application
    zvikaz
      My application is an C++ thik client application. It uses some king of lib (called zaf) for the UI.
      Can Flex be used for handling the UI of desktop application ?
        • 1. Re: Using flex for thik client application
          Gregory Lafrance Level 6
          You could use AIR (Adobe Integrated Runtime), in which most of the app is created in Flex, and some in AIR extensions, but there would be limitations. You can't execute native applications from AIR applications, so you can't execute Perl scripts, Java apps, etc. from your AIR app. You can of course use FDS (Flex Data Services) to connect to POJO, EJB, JavaBeans, SOAP and other web services, etc.
