4 Replies Latest reply on Mar 26, 2013 3:57 AM by [Jongware]
    how to find pointSize below 8
    Mahesh_JW
      Hi All,
      I want to generate a report with page and font name if the InDesign document contains font size below 8 points.
      plz reply ASAP.
      Regards
      Mahesh
        • 1. Re: how to find pointSize below 8
          What do you have, so far? Or do you need someone to write a custom script for you from scratch?
          • 2. Re: how to find pointSize below 8
            Mahesh_JW Level 1
            Thanks for your reply.
            This is what my code, but is this good idea or something in efficient?
            for(var num=7.9;num>=6;num = num - 0.1){
                      app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
                      app.findTextPreferences.pointSize = num;
                      var result = app.activeDocument.findText();
                      if(result.length>0){
                                for(var a=0;a<result.length;a++){
                                          result[a].select();
                                          //report page, font name
            Regards
            Mahesh
            • 3. Re: how to find pointSize below 8
              Jump_Over Level 5
              It should work basically however manually scaled text will be excluded (i.e 6.5435 pt)
              And I suggest to change last line:
                    result[a].select();
              to:
                    result[a].showText();
                    alert(a);
              to see effect
              Jarek
              • 4. Re: how to find pointSize below 8
                As Jarek mentions, this is not a very reliable method. It also would be kind of slow.
                Try using TextStyleRanges -- these are the internal "units of formatting" inside InDesign. Using everyItem, you can quickly gather the list of every formatted block. Then you can inspect each one at leisure:
                result = app.activeDocument.stories.everyItem().textStyleRanges.everyItem().getElements();
                alert (result.length);
                for (a=0; a<result.length; a++)
                if (result[a].pointSize < 8)
                  result[a].select();
