1. Re: Script for ID Dictionary
stephen0218 Mar 25, 2013 8:06 PM (in response to Maria964)Oh yes, doable, not particularly difficult.
2. Re: Script for ID Dictionary
Maria964 Mar 26, 2013 6:14 AM (in response to stephen0218)Hi, Stephen,
Thank you very much for you opinion. I think that this is doable and not particulary difficult (for you). For me it is rather difficult because I don't get along with scripting (I have tried...). But anyway I solved my problem: replace all the spaces between words with a paragraph, export to text and used grep in Nopepad++ to sort the words and delete the duplicates. With another quick proofing I will get a wonderful indesign user dictionary for medical terms.
Now another question: do you know any script that I can use to convert all the tables to text in a document?
Maria
3. Re: Script for ID Dictionary
stephen0218 Mar 26, 2013 12:30 PM (in response to Maria964)Finding the text in a table isn't hard ...
where do you want the table text to be put? in a new textFrame?
what do you need to do with the table text?
how do you want the table text to look?
what happens to the original table?
Making the table text look anything like the original table is, I think, hard. How would you do this "by hand"? The answer will tell us what the script needs to do, and what decisions a such a script would need to make.
4. Re: Script for ID Dictionary
Maria964 Mar 27, 2013 5:14 AM (in response to stephen0218)Hi, Stephen,
I have already solved my problem with the tables and the project «ID Medical Dictionary» is almost ready.
I really want to thank you for your help to someone that simply is not able to cope with scripting… I have started working in books with PageMaker 1.0 and I really do not know how I survived without scripting all these years. I have to be thankful to Google and to this script community…
I am a specialist in MathType and if someday you have a problem with that contact me.
Maria
5. Re: Script for ID Dictionary
[Jongware] Mar 27, 2013 6:01 AM (in response to Maria964)Here is a working Javascript to do the word gathering and sorting. There are straightforward ways to do this, but my script uses a couple of shortcuts that are possible with both Javascript (split arrays on a regular expression; remove duplicates by feeding the result into an object) and InDesign (using everyItem to quickly gather all possible text). So it may be kind of unclear what happens where
A problem (as you may have already have found out by yourself) is how to determine what a 'word' is. This script replaces common punctuation and digits with a space, and then only gathers what's left between the spaces. You are sure to find some weird "words" this way, but then again so does your manual way.
After processing, the script prompts for a Save File name and then opens it in your default plain text editor.
textList = app.activeDocument.stories.everyItem().texts.everyItem().contents.join('\r'); textList = textList.replace(/[.,:;!?()\/\d\[\]]+/g, ' '); textList = textList.split(/\s+/); tmpList = {}; for (i=0; i<textList.length; i++) tmpList[textList[i]] = true; resultList = []; i = 0; for (j in tmpList) resultList[i++] = j; resultList.sort(); defaultFile = new File (Folder.myDocuments+"/"+app.activeDocument.name.replace(/\.indd$/i, '')+".txt"); if (File.fs == "Windows") writeFile = defaultFile.saveDlg( 'Save list', "Plain text file:*.txt;All files:*.*" ); else writeFile = defaultFile.saveDlg( 'Save list'); if (writeFile != null) { if (writeFile.open("w")) { writeFile.encoding = "utf8"; writeFile.write (resultList.join("\r")+"\r"); writeFile.close(); writeFile.execute(); } } -
6. Re: Script for ID Dictionary
-hans- Mar 28, 2013 5:15 AM (in response to [Jongware])hi,
i thought of having a speedproblem using every item, so exported the stories ...
#target Indesign //http://www.shamasis.net/ Array.prototype.unique = function() { var o = {}, i, l = this.length, r = []; for(i=0; i<l;i+=1) o[this[i]] = this[i]; for(i in o) r.push(o[i]); return r; }; var storyFiles = new Array(); var currDoc = app.activeDocument; var docName = currDoc.name; var currStories = currDoc.stories.everyItem().getElements(); l = currStories.length; while(l--){ currStory = currStories[l]; currStory.exportFile(ExportFormat.TEXT_TYPE, File('~/Desktop/' + docName + l + '.txt')); storyFiles.push(File('~/Desktop/' + docName + l + '.txt')) } var masterStory = ''; l= storyFiles.length; while(l--){ currExport = storyFiles[l]; currExport.open('r'); masterStory = masterStory + currExport.read(); currExport.close(); currExport.remove(); } var finalCut =masterStory.replace(/[?,.!\n\r]/g,' ').split(' ').unique().sort().join('\n'); destFile = File('~/Desktop/' + docName.replace(/indd/, 'txt')); write_file(destFile, finalCut); destFile.execute(); function write_file ( _file, _data ) { _file.open( 'w' ); _file.encoding = 'UTF-8'; _file.write( _data ); _file.close(); } -
7. Re: Script for ID Dictionary
Maria964 Apr 2, 2013 5:09 AM (in response to [Jongware])Hi, Jongware.
First of all, thank you very much for your script. As usual “Jongware ROCKS”.
I apologize for being all this days without answering to your post but I took a few days for resting and I forbid myself of touching a computer, read emails, etc....
Maria
