2 Replies Latest reply on Mar 26, 2013 12:20 PM by foredit
    reply try catch till right paragraph name
    foredit
      Hi, I have to apply a paragraph style to grep preferences before a find cycle.
      If user input is a paragraph name not existing in the document the script outputs an error.
      First error rules right but second stops script. And, of course, I need to go ahead till right paragraph name.
      here's javascript
      app.findGrepPreferences = app.changeGrepPreferences = null;
      var myPara = prompt ("input a paragraph style", "");
      try {
          app.activeDocument.paragraphStyles.itemByName(myPara).name;
          alert ("This is a paragraph style!");
      catch (myError) {
          var myPara = prompt ("This is NOT a paragraph style! \rType existing style ", "")
      app.findGrepPreferences.appliedParagraphStyle = myPara;
      alert ("Correct! \nStyle applied in grep preferences!");
      Any idea? ...maybe a while  loop could resolve (tryied without success)
        • 1. Re: reply try catch till right paragraph name
          absqua Level 4
          No real need for try/catch here. This scenario is what the .isValid property is for. Example with while loop:
          var doc = app.activeDocument,
              promptText = "Input a paragraph style name.",
              shouldPrompt = true,
              tempStyle, style, name;
          while (!style && shouldPrompt) {
              name = prompt(promptText, '');
              if (name === null) {
                  shouldPrompt = false; // or skip the shouldPrompt checks and just exit(), if you prefer
                  continue;
              tempStyle = doc.paragraphStyles.itemByName(name);
              if (tempStyle.isValid) {
                  style = tempStyle;
              else {
                  promptText = "\"" + name + "\" is NOT a paragraph style!\rType existing style.";
          if (style) {
              // carry on with find/change
          Note that this will only find styles at the root level. If you have, or might have, paragraph style groups in your document, you'll need to loop through doc.allParagraphStyles instead.
          If I were doing this, I think I would just present the user with a dropdown of all the style names the document contains, and let them choose. You could use ScriptUI or just the normal InDesign dialog API. See "User Interfaces" in the Scripting Guide.
          Jeff
          Edited; Jive does weird stuff with <code> tags.
          • 2. Re: reply try catch till right paragraph name
            foredit Level 1
            Thanks for script ...you give me a lesson and "isValid" property light me.
            Change try/catch to a while loop so:
              while (!app.activeDocument.paragraphStyles.itemByName(myPara).isValid)
                {myPara = prompt ("\"" + myPara + "\" is NOT a paragraph style!\rType existing style")}
            Better as you told is a UI but I'm new to script so...
            thanks again
