4 Replies Latest reply on Mar 26, 2013 12:15 AM by Nickboy1965
    Autocomplete
    Nickboy1965
      Hi Sorry to ask such a basic question, i'm new to the world of creating PDF Documents.
      I have tried searching before posting this question as i couldn't seem to find a satisfactory answer.
      I want to be able to autocomplete a number of fields based on the contents that a user enters in one of the fields ( in this case an audit no )
      So  I set up two fields to test it
      Text1 and text2
      lookling at some answers on the we i came up with:
      Under custom calculation script of  text1's property box i've got:
      this.getField("text2").value = this.getField("text1").value;
      but nothing happens!
      any help would be greatly appreciated
      thanks
      Nick
        • 1. Re: Autocomplete
          While you are within a field the access to the field's properties and methods is by use of the "event" object.
          this.getField("text2").value = event.value;
          If I were setting another field from the current field, I wold us the "On Blur" action so the calculation is not repeated when any field used in any calculation is updated. On a large complex form this could improve performance.
          • 2. Re: Autocomplete
            Nickboy1965 Level 1
            thanks for the reply
            So if i put this:
            in the "on blur" event of text1 why does nothing happen?
            • 3. Re: Autocomplete
              You have to update the field and tab out of the field to trigger the "On Blur" or exit actilon.
              • 4. Re: Autocomplete
                Nickboy1965 Level 1
                I know, it still doesn't update the field.
                I have dicovered the duplicate field option which appears to update all instances of the field with the same name followed by a  #and a number.
                vba is so more dependable....
                thank you for your time
