Is there a way I can remove the breadcrumb from the popups (images) and still have them on the topic pages? Can I create a new masterpage and turn off the breadcrumb just for the popup topic pages?
I am using RoboHelp 10.
Tx.
Hi there
That's precisely how you would do it. Associate the Master Page with a Breadcrumbs placeholder only with the topics you want to have the breadcrumbs. Then ensure you disable global breadcrumbs in your Single Source Layout recipe. (if you don't, you will see a "double-helping" of breadcrumbs. And that... well, that, can be pretty... crummy)
Cheers... Rick
WOOOW Your good! Thank you so much!
Hi Rick
This didn't work. It removed it totally even though I added it to the topic Masterpages. Any other ideas?
This depends on exactly WHERE in the Master Page you added the breadcrumbs placeholder. It has to be OUTSIDE the Body placeholder. If it's INSIDE the placeholder, only new topics will receive the breadcrumbs. Existing topics will remain unaffected.
Cheers... Rick
Tax I will try this tomorrow.
Sent from Janet's phone to you.
Have a lovely day
Hi Rick
I tried to place the breadcrumb outside the Body but it keeps moving it into the Body part of the HTML code. Any suggestions.
<?rh-placeholder type="breadcrumbs" ph-align="2" sep-char=">" home="Home" usetopicformat="0" ph-style="font-family:Arial;font-size:8pt;font-weight: normal;font-style: normal;text-decoration: none;" ?> CODE FOR BREADCRUMB. I tried placing it in the header .. .didn't work, tried to do this on HTML page, but as soon as I save it gets moved to inside the Body ... how do I get around this? <?xml version="1.0" encoding="utf-8" ?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta name="topic-comment" content=""/> <meta name="generator" content="Adobe RoboHelp 10"/> <title>F_Text Page</title> <link rel="StyleSheet" href="default.css" type="text/css"/> <?rh-placeholder type="breadcrumbs" ph-align="2" sep-char=">" home="Home" usetopicformat="0" ph-style="font-family:Arial;font-size:8pt;font-weight: normal;font-style: normal;text-decoration: none;" ?> </head> <body> <?rh-region_start type="body" ?>
This is Body Placeholder text for your
Master Page. Topics created using this Master Page will get this text
by default. Replace
I will need to look at it from home -- it is blocked from the Fujitsu server.
Hi Rick, just to let you know I got them both working -- close button in popups and breadcrumbs in English and French.
Thank you for your help and ideas.
Janet
Hi Rick
Can you help me with this one. I am trying to have the online help open to a full size window or at least at a fixed window size.
I have someone that gave me the code but I am not sure what to do with it or how it identifies the size to make the window of the help when it opens.
This is the code that Guy provided but I don't know where to put the code:Here is the Javascript for the resize window. You can set the attribute to a specific size.
window.resizeTo(width,height)
or
You can expand the window to be the entire screen.
</html
