5 Replies Latest reply on Feb 10, 2014 9:48 AM by claudio_pais
    doc.AllGraphics crash in C#.
    AdobeInDesignScriptKiddie
      InDesign.Document doc = (InDesign.Document)app.Open(PathToInDesignFile, true); // works fine
      InDesign.Graphics allGraphics = (InDesign.Graphics)doc.AllGraphics; // crashes with an exception
      That's the exception:
      Unable to cast COM object of type 'System.__ComObject' to interface type 'InDesign.Graphics'.
      This operation failed because the QueryInterface call on the COM component for the interface with IID '{C85A4AB§-9492-...}' failed due to the following error:
      No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
      How to solve this problem?
        • 1. Re: doc.AllGraphics crash in C#.
          MrTIFF Level 3
          Well, I'm a JavaScript guy, but the object reference says that Document.allGraphics returns an Array, not a 'Graphics' object.
          • 2. Re: doc.AllGraphics crash in C#.
            AdobeInDesignScriptKiddie Level 1
            I've rewritten the Code to make it more clearly. The code now uses Graphic instead Graphics.
            Basically I get the same Exception, as I get:
            "Unable to cast COM object of type 'System.__ComObject' to interface type 'InDesign.Graphic'...
            Previously I got:
            int iCount = doc.AllGraphics.Count; // iCount is 1
            for (int i = 1; i <= doc.AllGraphics.Count; i++) // works
                 InDesign.Graphic graphic = (InDesign.Graphic)doc.AllGraphics[i]; // crash! Exception!
            So, anyone any ideas how to solve the problem?
            • 3. Re: doc.AllGraphics crash in C#.
              MrTIFF Level 3
              Well, aren't Arrays zero-based in C#?
              And you shouldn't need the cast at all.
              And I think Length is more standard than Count for the size of an Array ...
              • 4. Re: doc.AllGraphics crash in C#.
                I guess in the context of official InDesign scripting (Javascript, VBScript, Applescript) you are right.
                But I use ".Net C#" an the com-InDesign-Lib, so if I don't cast, then "doc.AllGraphics[i]" is just an object, and you could only use the following 4 methods:
                doc.AllGraphics[i].Equals
                doc.AllGraphics[i].GetHashCode
                doc.AllGraphics[i].GetType
                doc.AllGraphics[i].ToString
                That's the case in the context of classical NET-Programming.
                However in the context of .NET-C# InDesign-Com-Programming, arrays start with the index 1.
                If you use zero-based index then the exception "The requested member of the collection does not exist" appears:
                for (int i = 0; i < doc.AllGraphics.Count; i++)
                InDesign.Graphic graphic = (InDesign.Graphic)doc.AllGraphics[i]; // crash! (Value of "i" is "0" when it crashes here) Exception: The requested member of the collection does not exist
                Arn't there any Net-Programmers getting the same exception "Unable to cast COM object of type 'System.__ComObject' to interface type 'InDesign.Graphics'"?
                • 5. Re: doc.AllGraphics crash in C#.
                  claudio_pais
                  I have the same problem. Did you found any solution?
