2 Replies Latest reply on Nov 3, 2007 10:35 AM by zilvester
    Destination 'ColdFusionGateway' requires FlexClient support which was introduced in version 2.5.....
    zilvester
      Hopefully someone might recognise this error...
      Sadly it brings up only one result on google and that's a bit vague as to how that person got out of thier hole... :(
      I'm trying some very simple Flex Messaging with Flex Builder 2.0.1 and CF8 Standard (with LiveCycle 2.5.? built in)
      But I get this error:
      "Destination 'ColdFusionGateway' requires FlexClient support which was introduced in version 2.5. Please recompile the client application with an updated client framework."
      I guess the '2.5' is referring to LiveCycle?
      And I guess it's saying that the Flex compiler needs some updated elements to compile with so it can work with LiveCycle ?
      I think stepping into Flex for the first time just as FDS became LiveCycle was not a good idea.
      Strangely I (may have) narrowed it down to the gatewayid tag in messaging-config.xml
      eg:
      <gatewayid>*</gatewayid>
      OR <gatewayid>Flex2CF2</gatewayid>
      Which has been there well before LiveCycle. BUT If I remove this tag completely the error doesn't occur... then of course messaging doesn't work without it. Ho hum
      I can't see any DataServicesMessaging In/Outs using cf-polling-amf... I'm having more luck with cf-rtmp - I can see the 'In' and 'Out' counters ticking away when i view my ColdFusion Event Gateway Instance in the CF admin.
      So polling-amf won't connect, whereas rtmp will. Neither channel will 'subscribe' though.
      I've got ColdFusion Extensions 0.5.155475 installed (don't ask me how - it was a nightmare!) and working in Flex Builder 2.
      I tried bringing the flex/libs over to flex builder from CF as they were newer - no good
      I updated Flex Builder with:
      Flex 2.0.1 SDK with HotFix 3 from http://labs.adobe.com/technologies/flex/sdk/flex2sdk.html
      But nothing helps.
      here's the mxml:
      <?xml version="1.0"?>
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute"
      creationComplete="initApp()" viewSourceURL="srcview/index.html">
      <mx:Script>
      <![CDATA[
      import com.mikenimer.components.*;
      import mx.messaging.*;
      import mx.messaging.messages.*;
      import mx.messaging.events.*;
      public var pro:mx.messaging.Producer;
      public var con:mx.messaging.Consumer;
      public function initApp():void {
      pro = new mx.messaging.Producer();
      pro.destination = "ColdFusionGateway";
      consumer.subscribe();
      public function sendMessage():void {
      var msg:AsyncMessage = new AsyncMessage();
      msg.headers.gatewayid = "Flex2CF2";
      msg.body = new Object();
      msg.body.emailto = emailto.text;
      pro.send(msg);
      messagestatus.text = "Message sent to ColdFusion.";
      Debug.show(consumer);
      Debug.show(pro);
      private function messageHandler(event:MessageEvent):void {
      messagestatus.text = "Message received from ColdFusion.";
      private function faultHandler(event:MessageFaultEvent):void {
      messagestatus.text = "FAULT";
      Debug.show(event);
      </mx:Script>
      <mx:Consumer id="consumer" destination="ColdFusionGateway"
      message="messageHandler(event)"
      fault="faultHandler(event)" />
      <mx:TextInput x="103" y="13" width="291" id="emailto" editable="true"/>
      <mx:Button x="402" y="13" label="Send" id="emailsend"
      click="sendMessage();"/>
      <mx:Label id="messagestatus" x="103" y="350" width="291" text="Message
      not sent yet."/>
      </mx:Application>
      relevant bits from services-config.xml
      <channel-definition id="cf-polling-amf" class="mx.messaging.channels.AMFChannel">
      <endpoint uri=" http://{server.name}:{server.port}{context.root}/flex2gateway/cfamfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
      <properties>
      <polling-enabled>true</polling-enabled>
      <polling-interval-seconds>1</polling-interval-seconds>
      <serialization>
      <instantiate-types>false</instantiate-types>
      </serialization>
      </properties>
      </channel-definition>
      <channel-definition id="cf-rtmp" class="mx.messaging.channels.RTMPChannel">
      <endpoint uri="rtmp://{server.name}:2048" class="flex.messaging.endpoints.RTMPEndpoint"/>
      <properties>
      <idle-timeout-minutes>20</idle-timeout-minutes>
      <serialization>
      </serialization>
      </properties>
      the messaging-config.xml
      <destination id="ColdFusionGateway">
      <adapter ref="cfgateway" />
      <properties>
      </properties>
      <channels>
      <channel ref="cf-rtmp"/>
      <channel ref="cf-polling-amf"/>
      </channels>
      </destination>
      I tried some of this to no avail:
      <server>
      <max-cache-size>1000</max-cache-size>
      <message-time-to-live>0</message-time-to-live>
      <durable>false</durable>
      </server>
      <network>
      <subscriber-timeout>0</subscriber-timeout>
      </network>
      <network>
      <session-timeout>0</session-timeout>
      </network>
      why is it some lucky folk find it sooo easy? :
      http://www.onflexwithcf.org/index.cfm/2007/8/2/Coldfusion-8-Simple-messaging-example-using -Messaging-Event-Gateway
      it should be THAT easy dontcha think?
      help me please, please.
      Thanx
      VV
