5 Replies Latest reply on Apr 21, 2013 10:30 PM by AyukawaYukiko
    Unable to enable OpenCL in Photoshop CS6
    Dreamer90
      I have a Radeon HD 5670 card (640sp version) and I'm unable to activate the "OpenCL" option in Advanced Graphics Processor settings.
      My GPU driver version is Catalyst 13.3 beta 3 for windows 7. The problem occurs in Catalyst 13.2, too.
      GPU-z report: http://gpuz.techpowerup.com/13/03/25/4hw.png
      OpenCL works with Neat Image Plugin: http://i6.minus.com/iWACCYWkRDeKN.png
      Photoshop's System Info tool's report:
      Adobe Photoshop Version: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x32
      Operating System: Windows 7 32-bit
      Version: 6.1 Service Pack 1
      System architecture: Intel CPU Family:6, Model:15, Stepping:13 with MMX, SSE Integer, SSE FP, SSE2, SSE3
      Physical processor count: 2
      Processor speed: 2199 MHz
      Built-in memory: 2045 MB
      Free memory: 515 MB
      Memory available to Photoshop: 1664 MB
      Memory used by Photoshop: 60 %
      Image tile size: 128K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Advanced
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: True.
      OpenGL Allow Old GPUs: Not Detected.
      Video Card Vendor: ATI Technologies Inc.
      Video Card Renderer: ATI Radeon HD 5600/5700
      Display: 1
      Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1366
      Video Card Number: 1
      Video Card: ATI Radeon HD 5600/5700
      OpenCL Unavailable
      Driver Version: 12.100.17.0
      Driver Date: 20130318000000.000000-000
      Video Card Driver: aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiumdva.cap
      Video Mode: 1366 x 768 x 4294967296 colors
      Video Card Caption: ATI Radeon HD 5600/5700
      Video Card Memory: 1024 MB
      Video Rect Texture Size: 16384
      Serial number: Tryout Version
      Application folder: D:\Utilities\PhotoshopPortable\App\PhotoshopCS6\
      Temporary file path: C:\Users\HANAYU~1\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        C:\, 20.1G, 8.25G free
      Required Plug-ins folder: D:\Utilities\PhotoshopPortable\App\PhotoshopCS6\Required\
      Primary Plug-ins folder: D:\Utilities\PhotoshopPortable\App\PhotoshopCS6\Plug-ins\
      Additional Plug-ins folder: not set
      Can anyone suggest me a solution to solve this problem? Thanks.
        • 1. Re: Unable to enable OpenCL in Photoshop CS6
          Noel Carboni Level 8
          I don't believe Photoshop is designed to allow the use of OpenCL on a 32 bit system (Chris Cox or someone from Adobe will have to speak to why that is).  I have a 64 bit Windows 7 system and the OpenCL checkbox is grayed out in the 32 bit variant; it's only selectable in the 64 bit variant.
          -Noel
          • 2. Re: Unable to enable OpenCL in Photoshop CS6
            Ken eXs
            Im using AMD A8-4500M APU with Radeon(tm) HD Graphics HD7460 running on windows 8 x64.
            I have the same problem. I cant run photoshop extended. No 3D layer Menu and OpenCL Checkbox is DISABLED.
            • 3. Re: Unable to enable OpenCL in Photoshop CS6
              Level 7
              The 3D menu is present if you have an extended serial number.
              It would appear, but be grayed out if your system cannot handle 3D (like a bad GPU driver).
              • 4. Re: Unable to enable OpenCL in Photoshop CS6
                Regarding OpenCL on 64 bit Photoshop:  Try ATI Catalyst 13.3 beta 3.
                Important:  As of the time of this writing, no recently released ATI drivers work well with Photoshop.  That's why I'm suggesting the beta, which I have been running successfully for several weeks now.
                You will not be able to enable OpenCL in the 32 bit Photoshop, as described above.
                -Noel
                • 5. Re: Unable to enable OpenCL in Photoshop CS6
                  AyukawaYukiko
                  Additional information :
                  1. ATI Firepro V4900 with latest catalyst driver work with all advanced options (available)
                       in photoshop CS6 64bit (no 13.01 update applied yet, would try later)
                       on Intel CPU with P4000,
                       * please update to latest Intel drivers even using another GPU for display
                  2. Nvidia GT430 with latest driver with photoshop CS6 13.01 x64 on AMD Phenom II x6
                       got similar problem reported "OpenCL not available" from photoshop system information
                       GT 430 has latest nvidia driver installed, supporting OpenCL for photoshop
                       double check with GPUz reported problem with an unnecessary
                       ATI stream SDK driver installed (with CPU drivers).
                           (currently not using AMD for GPU, this driver is not in use)
                       once uninstalled ATI stream SDK driver from catalyst install manager,
                       OpenCL option available in photohsop,
                       GPUz also did not report error anymore.
                       This might help to reslove some of the problems with dimmed OpenCL option.
