0 Replies Latest reply on Mar 26, 2013 1:53 AM by peacea
    Bug - 'Save As' followed by 'Close' method
    peacea
      Hi
      When the following methods are called one after the other, it causes a bug in Illustrator. That is, user can no longer draw in Illustrator, unless the application is closed and restarted.
      Code with bug
      import flash.filesystem.File;
      Illustrator.app.activeDocument.saveAs(new File(File.desktopDirectory.nativePath + "\\test.ai"));
      Illustrator.app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      Work around
      If a time delay is put in between the saveAs() method and the close() then the bug goes away, e.g.
      var myfunc = function() {
      setTimeout( myfunc, 1000 );
      Anybody know what causes the bug, and if there is a better workaround?
