7 Replies Latest reply on Mar 27, 2013 7:41 PM by Mandy_Wiesener
    how to add to and cc fields via email submit button
    kellie21
      I have created a form which requires pdf format. I need the form to submit via email with the option to change/select the to: and also add a cc: field with selection as well. Please provide any information available as I am new to livecycle and am not very familiar with script or code.
      Thanks!
        • 1. Re: how to add to and cc fields via email submit button
          Mandy_Wiesener Level 3
          You can do the following:
          You have to use a normal button!!
          //fill in e-mail
          var Mailto = Formular1.s1.email.rawValue;
          //var Mailto = "test@test.de";
          //fill in subject
          var SubjectBetreff = Formular1.s1.betreff.rawValue;
          //var Betreff = "Test-Betreff";
          //fill in message
          var MessageNachricht = "Content PDF:\r" + "Field content: " + Formular1.s1.inhalt.rawValue + "\rName: "
          + Formular1.s1.name.rawValue + "\rDatum: " + Formular1.s1.datum.formattedValue;
          //var Nachricht = "This is a test message.\r2.row start here.\r3.row here.";
          //fill in e-mail cc
          var CC = Formular1.s1.emailcc.rawValue;
          //var CC = "testcc@test.de";
          //fill in e-mail bcc
          var BCC = Formular1.s1.emailbcc.rawValue;
          //var BCC = "testbcc@test.de";
          var Mail = "mailto:" + Mailto + "?Subject=" + SubjectBetreff + "&Body=" + MessageNachricht + "&cc=" + CC + "&bcc=" + BCC;
          //cSubmitAs: "PDF" send the pdf as attachment
          //cSubmitAs: "XML" send the pdf as xml-attachment
          event.target.submitForm({
          cURL: Mail,
          bEmpty: true,
          cSubmitAs: "XML"
          Hope it will helps you,
          Kind regard Mandy
          • 2. Re: how to add to and cc fields via email submit button
            kellie21 Level 1
            Hi there. Thank you for your reply. I pasted what you sent and I am receiving the following:
            The following error was found with the XML source:
            xml parsing error: not well-formed (invalid token)(error code 4),
            line 772, column 70 of file
            The line in question is:
            var Mail = "mailto:" + Mailto + "?Subject=" + SubjectBetreff + "&Body=" + MessageNachricht + "&cc=" + CC + "&bcc" + BCC;
            (the indicated error site is the "y" in "&Body=")
            What do Betreff and Nachricht mean? And what I really need for the "to:" field is to have the option to select a name/email or leave the "to:" field blank so they can type in manually. Could you assist with this?
            I appreciate any information!
            • 3. Re: how to add to and cc fields via email submit button
              darje6666
              Try this.
              PDF attached. Just open in LiveDesigner.
              udrugasasrcem.com/tocctest.pdf
              • 4. Re: how to add to and cc fields via email submit button
                kellie21 Level 1
                Hello, thank you for your reply. I believe this what I want but am having difficulties implementing it into my form. I created the "send email" button, to: and cc: fields and pasted the script information but I continue  to receive error codes.
                The script issue seems to be quite confusing for me. I am very new to this and would like to know if you could perhaps walk me through this process.
                • 5. Re: how to add to and cc fields via email submit button
                  darje6666 Level 1
                  Can you send me your form please at dariobukovski@yahoo.com so i can take a look at those errors?
                  • 6. Re: how to add to and cc fields via email submit button
                    kellie21 Level 1
                    Thank you so much for your assistance. I have attempted to insert the email addresses but apparently I am doing this incorrectly as I try to test the form and the email addresses do not show up or populate in an email window. It basically does nothing. I have tried numerous ways and still no result.
                    Could you please instruct me the exact location to enter this information?
                    • 7. Re: how to add to and cc fields via email submit button
                      The name if you don't understand is only a name for the variable and is an combination from english and german.
                      Subject is the english word for Betreff
                      Message is the english word for Nachricht.
                      You could use this:
                      //fill in e-mail
                      //fill in subject
                      var SubjectEmail = Formular1.s1.betreff.rawValue;
                      //var SubjectEmail = "Test-Subject";
                      //fill in message
                      var MessageEmail = "Content PDF:\r" + "Field content: " + Formular1.s1.inhalt.rawValue + "\rName: "
                      + Formular1.s1.name.rawValue + "\rDate: " + Formular1.s1.dateEmail.formattedValue;
                      //var MessageEmail = "This is a test message.\r2.row start here.\r3.row here.";
                      //fill in e-mail cc
                      var Mail = "mailto:" + Mailto + "?Subject=" + SubjectEmail + "&Body=" + MessageEmail + "&cc=" + CC + "&bcc=" + BCC;
                      cURL: Mail,
                      bEmpty: true,
                      cSubmitAs: "XML"
                      I come from Germany and this is my script (therefore in german) I have try to change the german words in english words...
                      Here you will find an example: https://workspaces.acrobat.com/?d=4adT3ExjCSsr7HpoDuKq7Q
                      Helpful?
                      Mandy
