2 Replies Latest reply on Mar 26, 2013 9:24 AM by sircrom
    CFDocument(PDF) - Fonts
    sircrom
      CFDocument does not render my fonts in the PDF
      I tried the following things:
      • Add the Font in the CFAdmin(.ttf)
      • Try to use the <font> - Tag instead of CSS
      • Add the Font via @font-face in CSS
      I use Coldfusion 9 on Linux
      Here is the code, which i use to generate my PDF
        <CFFILE action="write" file="mydocument.pdf" output="#content#" mode="777" />
        <cfheader name="Content-Disposition" value="attachment; filename=mydocument.pdf">
        <cfcontent type="application/pdf" variable="#content#" />
        • 1. Re: CFDocument(PDF) - Fonts
          Dan Bracuk Level 5
          Why are you using cffile instead of cfdocument or cfpdf?
          • 2. Re: CFDocument(PDF) - Fonts
            sircrom Level 1
            That's only a intermediate step to save my pdf on the server.
            My Codeorder looks like this:
            <CFDOCUMENT name="content" format="pdf" pageType="A4" localurl="yes" fontembed="no" marginbottom="0" margintop="1" unit="cm">
                 <!--- MY HTML --->
            </CFDOCUMENT>
