9 Replies Latest reply on Mar 26, 2013 7:01 PM by Genevieve Laroche
    Submit Button - "Visible but doesn't print" (Form Field)
    sublogic
      Hello, I am new to Forms Central and would like to inquire about the embedded "Submit Button" that FormsCentral embeds into a PDF in order to collect responses.
      Is there a way to enable the "Visible but doesn't print" option to this particular form field that FormsCentral creates? I would like to print the documents at the same time as I submit them, basically knocking two birds with one stone.
      Currently if you try to print the document, the "Submit Button" shows up in the document. In order to print the document without the button, you need to use the "Save as PDF" which will create a PDF with the collected response. This is essentially an extra step in automating the whole process as you can only save one PDF at a time.
      I would appreciate any insight with this particular issue, thank you.
