5 Replies Latest reply on Mar 28, 2013 7:08 AM by MadMac55
    Find first line in every column
    BEGINNER_X Level 3
      Hi All,
      Request:
      I want to find first line in every text frame column.
      Bug:
      If the active document contains single column, two column and multiple column text frames. In that case I am not able to get my result
      Trying script:
      var myDoc = app.activeDocument
      var myTextFrames = myDoc.textFrames.everyItem().getElements()
      for(i=0; i<myTextFrames.length; i++)
            var myTextColumns1 = myTextFrames[i].textColumns[1].lines[0].contents
                alert(myTextColumns1)
      Herewith i attached the error file.
      If active document contains only two column text frame, script run sucessfully.
      If active document contains single column text frame and two column text frame error found as below:
      Could anyone find solution for my request.
      Thanks in advance
      BEGINNER
