15 Replies Latest reply on Mar 29, 2013 5:38 AM by keith5000g
    app.openDoc works in Acrobat, not in Reader
    keith5000g Level 1
      In a folder-level script I'm using app.openDoc to open an existing PDF and extract an icon from it. The following code works in Acrobat 11 but in Reader X I get a NotAllowedError: Security settings prevent access to this property or method error.
      this.disclosed = true;
      myIcon = app.trustedFunction(function (oArgs) {
           app.beginPriv();
           var pluginPath = app.getPath({ cCategory: "app", cFolder: "javascript" });
           var myDoc = app.openDoc({ cPath: pluginPath + "/MyImages.pdf", bHidden: true });     // <----- error happens on this line
           var oIcon = util.iconStreamFromIcon(myDoc.getIcon("myIcon"));
           app.endPriv();
           return oIcon;
      The MyImages.pdf exists in the same Javascripts folder as the javascript file. I created MyImages.pdf manually via the console and set disclosed=true before saving it.
      I've also tried modifying the call to app.openDoc to set oDoc:this (as recommended in other discussions) but that only caused the same NotAllowedError in both Acrobat and Reader.
      Any ideas?
