3 Replies Latest reply on Mar 29, 2013 12:07 PM by Jim_Simon
    Can't Change Sequence Settings (Work-Around?)
    Gordon James McDowell Level 1
      Having the grey-ed out Sequence Settings for already created sequence has me thinking I've done a lot of work I can't recover.
      I created my sequence from some footage that was lower-frame-first (I thought all my footage was progressive). Into this LFF sequence in put in sync all my multicam footage. Call it Sync_v01.
      I created another sequence based on Sync_v01 called Edit_v01. Edit_v01 is where I did most of my actual work.
      They're both LFF (me being unaware Sync_v01 was LFF so I spread the error when I created one sequence from the other). They should have been progressive (almost all the footage is progressive). Doh!
      It is easy enough to recover Sync_v01 (LFF) into Sync_v02 (Progressive). Copy/paste.
      But I don't see how I can recover my work in Edit_v01 (LFF) into an Edit_v02 (Progressive) where I'm citing footage in Sync_v02... all the clips are still Sync_v01.
      If I could change Sequence Settings of course this would allow me to correct my mistake instantly.
      But I'm not sure I can recover my edit work at all? And I need to redo it all? Or else be stuck with LFF (incorrect) sequence setting?
      Hoping I'm missing an obvious solution here.
