1 Reply Latest reply on Mar 28, 2013 6:14 AM by Jump_Over
    Find H1 style in Top of Frame only
    BEGINNER_X Level 3
      Hi Everyone,
      Request:
      I want to find "H1" style in top of frame only. It is two column book.
      If "H1" style comes in both the columns 1 and 2.
      Problem:
      Document using span columns, so the script will find all the  H1 style falls in first line of every column.
      Trying script in  ways:
      var myDoc = app.activeDocument
      app.activeDocument.viewPreferences.horizontalMeasurementUnits = app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
      var myTextFrame = myDoc.textFrames.everyItem().getElements()
      for(i=0; i<myTextFrame.length; i++)
              if(parseInt(myTextFrame[i].geometricBounds[3] - myTextFrame[i].geometricBounds[1]) == 180)
          for(j=0; j<myTextFrame[i].textColumns.length; j++)
              if(myTextFrame[i].textColumns[j].lines[0].appliedParagraphStyle.name == "H1")
                  alert("H1 in First line of Frame\n"+ "Contents:" + myTextFrame[i].textColumns[j].lines[0].contents + "Page number: " + myTextFrame[i].textColumns[j].lines[0].parentTextFrames[0].parentPage.name)
                  app.select(myTextFrame[i].textColumns[j].lines[0].parentTextFrames[0])
                  exit(0)
      Could anyone please give solution.
      Kindly check the screenshot
      Thanks in advance
      Beginner_x
        • 1. Re: Find H1 style in Top of Frame only
          Jump_Over Level 5
          A solution could be to compare .endBaseline properties.
          i.e.:
          myTextFrame[i].textColumns[0].lines[0].endBaseline ==> this could be a base for textFrame [i]
          so make the next if startement with two conditions:
          - proper paraStyle
          - proper endBaseline of 1st line of x textColumn (equal or "no higher then...")
          rgds
          Jarek
