We use RoboHelp version 9.0
Project description
We have a Parent project with 7 child projects. Each child project has, on an average, 40 files.
The files in each child project are linked to word documents. Every time we have updates to content, we update the word file and click Update in RH project.
All the child projects are merged in the parent project via TOC.
On completion of updates in the individual projects, we generate the individual projects and then generate the parent project for final output.
Our project structure is like this, where each circle represents a folder.
The issue
The issue we face is about See also links.
Each word file in almost all projects has “See also” topics without links in the word document. However, we hyperlink them with .htm files (within the child project and between child projects) in RH.
Because the links are set in RH and the content updates are made in linked word files, whenever we modify the word files and update them in RH, the links are lost. We need to manually go to each file in RH and re-hyperlink them. Although we select the “Preserve modifications to this file” before we save in RH, the links are still lost.
In addition to losing the hyperlinks, a duplicate file gets created for each file in backend. We have to manually delete each file.
My questions
3. Is linking the word files the best practice? My organization insists on maintaining word documents.
If you organisation insists on using Word then there is little you can do about that and linking your Word files to RH is the best option. Unfortunately though there is little you can do to prevent the links being lost when you update the Word links. This is in effect a dump of the Word file which replaces the content of the RoboHelp topics. Perhaps you could add the links in the word file but use the actual path that you'd add if you were adding the link in RH.
Thank you for the response. I did try adding the actual path in the word. It works in my machine but not in another machine.
According to this, Rh is compatible with SVN.
http://www.adobe.com/devnet/robohelp/articles/robohelp_subversion.html
Thank you for the response and the URL. This will help. Thanks.
