• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Looping ppt for use as lobby layout
Guest
Mar 28, 2013 Mar 28, 2013
Hello - How can I take a continuous looping powerpoint presentation and have it continuously loop when I upload and use it for Share Document in Share pod?  And, can this be accomplished without have to buy any additional Adobe products, other than Adobe Connect? My intention is to use it in my Lobby Layout.
Thank you.
TOPICS
Desktop application
Views
8.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
LEGEND , Mar 28, 2013 Mar 28, 2013
This can be accomplished without purchasing Presenter, but it is a multi-step process. Here is how you would do it:
  1. Upload your PPT to the Connect server (preferably the Content Library)
  2. Download the output files that the server generates to create the Flash version of your presentation. Should be pulled down as a zip.
  3. Un-zip the output files.
  4. Go into the data folder.
  5. Locate the viewer.xml file
  6. Open in Notepad or some other program that will let you modify an XML file.
  7. On line two, add loop="true". I p
Votes
Translate
Translate
Explorer , Nov 25, 2020 Nov 25, 2020
Instead of trying to correct the XML files and using a ZIP file
Why don't you Export the PowerPoint presentation as an animated GIF i.e.
Then you can drag and drop it into the Share Pod and this will loop for you!
Votes
Translate
Translate
LEGEND ,
  7. On line two, add loop="true". I placed this after start="play" (see image below).
  8. Save the viewer.xml file.
  9. Re-zip the output files.
  10. Upload the zip to the Connect server or your Share pod, and when you press play the file should loop.
If you did get Presenter, you could check the box to loop the presentation and it does this work for you.
Votes
Translate
Translate
Report
Report
Guest
Thank you!
Bill
Votes
Translate
Translate
Report
Report
Guest
Mar 29, 2013 Mar 29, 2013
Hello,
Still not successful in getting presentation to loop for my Lobby Layout.
Question: Do I need to have “Loop continuously” selected for my presentation before downloading for the server to create a Flash version? (Tried it both ways with no success.)
After editing the viewer.xml file and saving in Notepad, the second line shows as follows:
Does the order of these two instructions matter?
Thank you.
Bill
Votes
Translate
Translate
Report
Report
LEGEND ,
The order may not be important, but I would keep it exactly as the output expects to see it.
I created a two slide presentation and did the steps listed above. I have both versions in the following room. The one on the left is without the loop="true" and the one on the right is with that code added too it. That is the only difference between them, and the loop works for me. I have the player skin showing to help illustrate what is happening.
http://realeyesconnect.adobeconnect.com/openroom
Selecting the loop option in PPT will have no affect on this setting. Is that where you are checking the Loop continuously option?
Votes
Translate
Translate
Report
Report
Guest
Success! I saw from your demo that I had to un-sync the Share Pod. Now it loops.
Thank you.
Votes
Translate
Translate
Report
Report
LEGEND ,
You should be able to do it with the share pod sync'd. That just makes sure that everyone else is seeing the looped presentation as well.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 21, 2013 Aug 21, 2013
Here is my code: When I rezip and upload it does not loop.
anything I am doing wrong? Pod is synched, forced presenter view.
<presentation width="720" height="540" preview="0" defaultSlideDuration="5" start="play" buildNum="8.0.0.227" loop="true" after start="play">
Votes
Translate
Translate
Report
Report
LEGEND ,
Not sure that it matters, but Presenter places loop="true" before the buildNum. Also, you have start="play" twice. That could be causing an issue. I'd remove the one after the loop= call.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 20, 2017 Jul 20, 2017
As a non -IT person, I am doing my best to follow the instructions on how to loop a PPT presentation - I can get through steps 1-4 above with no problem. However, you can see below that the only "view" file is "swf" and will only open in my browser ( I am using IE)
Are there different instructions for PPT 2010?
Votes
Translate
Translate
Report
Report
LEGEND ,
The process hasn't changed since I originally posted it.
It looks like you are skipping step 4. You need to go into the data folder in the zip of the output. There may be more files and folders than what was in the older versions of Presenter that Connect used. The output is not dependent on the version of PPT.
In the data folder, you will find the viewer.xml file.
Does that help?
Votes
Translate
Translate
Report
Report
New Here ,
Aug 11, 2020 Aug 11, 2020
Jorma, do you know if these steps are still correct? I'm getting an error trying to upload the re-zipped file. Thanks!
Votes
Translate
Translate
Report
Report
LEGEND ,
They should still apply. Make sure you aren't zipping the files in a folder. You want the collection of files and folders at the top level of the zip file. It's very easy to accidentally zip a folder of the output so the files used are one sub-folder deep and they may not run correctly.
Votes
Translate
Translate
Report
Report
Guest
Apr 01, 2013 Apr 01, 2013
Strangely, I had a user with an older version of PPT presentation that would loop in the Connect meeting. I now use that PPT and change the info for every Lobby slideshow I need.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 15, 2017 Nov 15, 2017
Hello,
I have a similar issue - I followed the steps provided to modify the code but even with the correct code in viewer.xml (in Data folder; uploaded in Content library) the slides do not loop (I also adjusted the speed of the slide show to 7 seconds instead of 5 and this does not reflect in the meeting room either). The strangest thing is that it worked once but after adjusting the slides content it doesn't anymore. Any suggestions? Here is the code:
<?xml version="1.0" encoding="UTF-8"?>
<presentation viewerPatch="11.0.2.156" buildNum="11.0.2.155" start="play" loop="true" defaultSlideDu...<search url="srchdata.xml"/>
<presentationBg url="bg.swf"/>
Votes
Translate
Translate
Report
Report
New Here ,
Oct 22, 2020 Oct 22, 2020
Hey there, first of all: Thanks for this great tutorial. It helped me a lot.
After the update to version 11 it seems that it doesn't working anymore. My old looped presentation - which worked fine until the update - isn't looping. I already uploaded an other presentation and did exactly the same as before but without a satisfying result. I'm using the new overlay/ ui in adobe connect (I have to say that I have'nt tried it in the old ui and to be honest I'd like to work with the new ui). When I upload the presentation often it wont even change the slide after pressing play. And at the end it stops instead of looping it.
Did I miss something? Is there anyone with the same problem?
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 30, 2020 Oct 30, 2020
You didn't miss anything. The shift from Flash to HTML means that the files behind the scenes are different. The old xml file that we could modify previously doesn't apply to an HTML presentation. We've not yet found the method of changing the presentation to loop without the use of Adobe Presenter.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Nov 05, 2020 Nov 05, 2020
Hi! I was able to get mine to loop, but it pauses after 1 second on each slide. Any ideas on how to fix this?
Votes
Translate
Translate
Report
Report
Explorer ,
Votes
Translate
Translate
Report
Report
I love this idea! Thank you. I will give it a shot!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 22, 2022 Mar 22, 2022
GiFs aren't a supported file type 😞
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 23, 2022 Mar 23, 2022
What version of Adoeb Connect are you using?
GIFs are a supportted file type for Share Pods since version nine.  See
Best practices | Uploading files (adobe.com)
Votes
Translate
Translate
Report
Report
The method above did work for me! I have been able to share the presentation as a gif and upload it into a share pod. I now not only have a looping slideshow, but also a rotating banner for other layouts.
Votes
Translate
Translate
Report
Report
New Here ,
Our organisation supplies us with 10.6.2
But I got it to work using the code edit method.
In our workspace, gifs don't work.
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 24, 2022 Mar 24, 2022
LATEST
If you are using an earlier version than 11 then the use of GIFs would not have worked.
Adobe Connect 10 is built to use Adobe Flash player so the code amendments cited earlier in this thread will work; indeed it what I used until our company upgraded to version 11.
Adobe Flash is no longer available and support for Adobe Connect 9 and 10 will end in 2023.
Votes
Translate
Translate
Report
Report
