2 Replies Latest reply on Mar 28, 2013 4:18 PM by PeterPow
    Graphic layer options
    PeterPow
      Hi guys,
      I'm experimenting with imported pages and the possibility to hide specific layers of an placed indesign document. To achieve this I am using the following code:
      var oDoc = app.documents[0]; // this is an empty document in the indesign client
      var oPlacedObjects = oDoc.pages.firstItem().place(File('{PATH_TO_FILE}'));
      var oImportedPage = oPlacedObjects[0];
      oImportedPage.graphicLayerOptions.graphicLayers.item(0).currentVisibility = false;
      oImportedPage.graphicLayerOptions.graphicLayers.item(1).currentVisibility = false;
      The placed file has 3 different layers, the first two I would like to hide. My problem now is that the second call to the currentVisibility-property always fails with the error message "The requested action could not be completed because the object no longer exists". When I extend my code to the following block
      // THIS LINE HAS BEEN ADDED
      var oImportedPage = oDoc.pageItems.firstItem().importedPages.firstItem();
      the script works as expected. My question now is if I'm doing something wrong in handling imported pages or if it is a bug, that the first script block does not work.
      Thanks for your support guys!
