2 Replies Latest reply on Mar 30, 2013 11:33 AM by Yogesh Upadhyay
    fsresource - runmode config stored in crx via xml
    Omega-Psi Level 1
      Hi, i'm using the fsresource sling extension to access the filesystem when working on JSP, JS, CSS and so on. When just yanking the bundle into the crx and configuring it via the OSGi console, everything works as expected. But when i try to add a new runmode (configurtion), the result is unsatisfying.
      Is the path of the main configuration, which i'm using on a local instance to figure out, how to achieve the desired results, but the best i could get was an unbound configuration displayed in the system/console/configMgr. The contents of the XML file:
      <?xml version="1.0" encoding="UTF-8"?>
      <jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0"
