2 Replies Latest reply on Nov 12, 2007 2:28 AM by Akshay_Gautam
    Problem Identifing A Visual Component
    Akshay_Gautam
      Hi, I am stuck in a situation where I am using an ActionScript visual custom component, which extends a VBox container. Lets call this component as MyComponent here. This MyComponent includes several other visual components viz, labels, a grid and 6 images inside the grid. All images have been assigned an id to uniquely identify each of them.
      I am using this visual custom ActionScript component inside a Grid recursively. Now I want to identify each of the MyComponent's images from those Grid elements.
      Please suggest me a way to identify which image of MyComponent I am referring to, as I am using MyComponent, where the position of image is inside mycomponent's grid's element position."
      Also intimate me about the user_names and other authentications required for respective forums you are registering to.
      Akshay.
        • 1. Re: Problem Identifing A Visual Component
          Gregory Lafrance Level 6
          I would think you could either refer to the MyComponent instances in the Grid by getChildAt or perhaps create IDs on the fly as they are created by appending a number within a loop.
          • 2. Re: Problem Identifing A Visual Component
            Akshay_Gautam Level 1
            Thanks for the reply. The problem lies in identifying the component while clicking on the image. Here I have an array of mouse images in the Cage class. I want to identify which arrMouse instance is being clicked on the Grid.
            Here is the code where I am calling my component with name Cage.
            private function addGrid():Grid
            var gridRows:int = 10;
            var gridCols:int = 5;
            var lGrid:Grid = new Grid();
            var arrGridRow:Array = new Array(gridRows);
            var arrGridCol:Array = new Array(gridCols);
            for (var rowNum:int = 1; rowNum <= gridRows; rowNum++)
            arrGridRow[rowNum] = new GridRow();
            for (var colNum:int = 1; colNum <= gridCols; colNum++)
            arrGridCol[colNum] = new GridItem();
            var cageNew:Cage = new Cage();
            arrGridCol[colNum].addChild(cageNew);
            arrGridRow[rowNum].addChild(arrGridCol[colNum]);
            lGrid.addChild(arrGridRow[rowNum]);
            return lGrid;
            Here is my component class Cage:
            public class Cage extends VBox
            //These variables are for creating visual components.
            private var cageDesc:HBox;
            private var cageName:Label;
            private var cageGenotype:Label;
            private var cageNo:Label;
            private var mouseRack:Grid;
            private var mouseRackRow:GridRow;
            private var mouseRackRowItem:GridItem;
            //private var mouse1:Image;
            private var arrMouse:Array = new Array(total_slots);
            private var timer:Image;
            //This is the only property added for this class.
            [Inspectable(defaultValue="From Class")]
            private var _txtVal:String;
            //These variables are for RemoteObject related functions.
            private var mouseRO:RemoteObject;
            private var cage_id:int = 344;
            private var slot_id:int;
            private var total_slots:int = 5;
            public var mouseGender:int;
            private var event:ResultEvent;
            public function Cage()
            addEventListener(FlexEvent.INITIALIZE, initializeHandler);
            public function get txtVal():String
            return _txtVal;
            public function set txtVal(value:String):void
            _txtVal = value;
            //dispatchEvent(new Event("numButtonsChange"));
            public function useRemoteObject():void
            mouseRO = new RemoteObject();
            mouseRO.source = "cfide.samples.test.cf.institution";
            mouseRO.destination = "ColdFusion";
            mouseRO.GetMouseByCageId.addEventListener("result", GetMouseInfoResultHandler);
            mouseRO.addEventListener("fault", faultHandler);
            mouseRO.GetMouseByCageId(cage_id, slot_id);
            Alert
            //here 344 is cage_id and 1 is slot_id.
            public function GetMouseInfoResultHandler(event:ResultEvent):void
            mouseGender = event.result.getItemAt(0).mouse_gender_id;
            //Alert.show(String(event.result.getItemAt(0).mouse_gender_id));
            //Alert.show(String(mouseGender));
            private function faultHandler(event:FaultEvent):void
            // Deal with event.faultstring, etc.
            Alert.show(event.fault.faultString, 'Error');
            // Gets called when the component has been initialized
            private function initializeHandler(event:FlexEvent):void
            // Display the component
            paint();
            private function paint():void
            // Create the number cageDesc
            cageDesc = new HBox();
            cageName = new Label();
            timer = new Image();
            cageName.width=90;
            cageName.height=16;
            cageName.text=_txtVal;
            timer.source = "../Assets/clocktimerGray.gif";
            cageDesc.addChild(cageName);
            cageDesc.addChild(timer);
            addChild(cageDesc);
            cageGenotype = new Label();
            cageGenotype.width=90;
            cageGenotype.height=16;
            cageGenotype.text="GenoType";
            addChild(cageGenotype);
            cageNo = new Label();
            cageNo.width=90;
            cageNo.height=16;
            cageNo.text="CageNo";
            addChild(cageNo);
            mouseRack = new Grid();
            mouseRackRow = new GridRow();
            mouseRackRowItem = new GridItem();
            for(slot_id = 1; slot_id <= 5; slot_id++)
            useRemoteObject();
            arrMouse[slot_id] = new Image();
            switch(mouseGender)
            case 1:
            arrMouse[slot_id].source = "../Assets/mouseMale.gif";
            break;
            case 2:
            arrMouse[slot_id].source = "../Assets/mouseFemale.gif";
            break;
            case 3:
            arrMouse[slot_id].source = "../Assets/mouseOther.gif";
            break;
            case 4:
            break;
            default:
            arrMouse[slot_id].source = "../Assets/mouseGray.gif";
            break;
            mouseRackRowItem.addChild(arrMouse[slot_id]);
            /*mouse1 = new Image();
            mouse1.source = "../Assets/mouseGray.gif";
            mouseRackRowItem.addChild(mouse1);*/
            mouseRackRow.addChild(mouseRackRowItem);
            mouseRack.addChild(mouseRackRow);
            addChild(mouseRack);
            Now when I am clicking on any image of arrMouse array in the visual display, I am unable to get the instance of mouse
            clicked.
            Please suggest me some way of accessing the arrMouse array element image.
