1 Reply Latest reply: Mar 29, 2013 6:29 AM by kglad RSS
    Buggy IF statement
    Nickels55 Community Member
      Here is the actionscript on the frame:
      if (newscore>=_level0.score1){
      trace("new high score");
      trace("new score = " + newscore);
      trace("old score = " + _level0.score1);
      trace(newscore + ">=" + _level0.score1);
      _level0.score1++;
      newscore++;
      }else{
      trace("not high score");
      Here is the output:
      new high score
      new score = 5
      old score = 10
      5>=10
      new score = 6
      old score = 11
      I am so confused on this output. The if statement compares two variables and says "if" the new score (newscore) is greater than or equal to the old score (_level0.score1) to do something. It is clearly not the case as you can see the new score is lower than the old score, but it is still acting like it meets the "if" requirement. This is for a local scoreboard using shared objects to store variables. I added the ++ to the variable to make sure the values were integers and not strings. What am I doing wrong here?
        • 1. Re: Buggy IF statement
          kglad CommunityMVP
          if you use:
          trace("new TRACE");
          _level0.score1++;
          newscore++;
          }else{
          and you're trace output is:
          new TRACE
          new score = 5
          old score = 10
          5>=10
          new score = 6
          old score = 11
          post a link to your zipped source files.
          if you're trace is the same as the one you posted, you have other code causing that problem.
