0 Replies Latest reply on Mar 29, 2013 11:03 AM by jmw107
    Gradient Feather Settings CS3 JS
    jmw107
      Hello:
      Hi -- Odd thing with the following snippet:
      for (var i = (app.activeDocument.rectangles.length - 1); i >= 0; i--) {
      var myrec = app.activeDocument.rectangles[i];
                if (myrec.label == "mygraphic") {
      myrec.transparencySettings.gradientFeatherSettings.angle = -90;
      The object appears to lose all gradients. However when I check the settings in InDesign, the change to -90 degrees has happened and all the other gradient settings have been preserved. But I have to redo the settings for the change to actually happen on the page.
      If i run this with an angle of 45, it works fine.
      Any idea what I might be doing wrong?
      Is this a problem with negative numbers? If so, Is there any workarounds?
      Any help would be greatly appreciated.
      thanks in advance
