1 Reply Latest reply on Mar 29, 2013 4:47 PM by booyajamo
    set fonts and styles based on xml parent's attribute
    patchlab
      I am trying to write an Indesign javascript that can set the font and style based on the import XML parent's attribute,
      <products>
      <product>
          <language value="EN"><feature_1>1000w</feature><feature_2>10 max</feature_2></language>
          <language value="JP"><feature_1>500w</feature><feature_2>2 max</feature_2></language>
          <language value="TCN"><feature_1>750w</feature><feature_2>5 max</feature_2></language>
      </product>
      <product>
          <language value="EN"><feature_1>2000w</feature></language>
          <language value="TCN"><feature_1>2500w</feature><feature_2>2 max</feature_2><color>red</color></language>
      </product>
      </products>
      each feature tag will be in its own tag frame.
      all the sub-set under language value="EN" will have like Univers font, font size 100%, align to left  (which mean 1000w, 10 max, and 2000w will be this)
      all the sub-set under language value="TCN" will have Sim Hei font, font size 100%, align to right
      all the sub-set under language value="JP" will have MS Gothic font, font size 125%, align to left
      I am new to indesign scripting, can someone point me to the right direction to get this started?
        • 1. Re: set fonts and styles based on xml parent's attribute
          booyajamo
          Hello,
          You can define the paragraph styles something like:
          var myParagraphStyle = app.activeDocument.paragraphStyles.add ({
               appliedFont: "Univers",
               pointSize: 12
          Then you can create an import map (to map the defined styles to your XML elements) like:
          var myImportMap = app.activeDocument.xmlImportMaps.add ("myTagName", myParagraphStyle);
          Then you import the XML
          app.activeDocument.importXML (File ("C:/xmlfile.xml"));
          Then place the XML on your page (you can do this several different ways)
          app.activeDocument.pages[0].placeXML (app.activeDocument.xmlElements[0], [0,0], true);
          I'd be interested to know if others have had issues with mapping styles to XML elements when you place the XML? Even on extremely small documents (approximately 2 pages of content) my INDD crashes when I have mapped styles. Non-mapped XML elements place fine.
          Lindsay
