8 Replies Latest reply on Apr 1, 2013 11:23 AM by wimkees
    Go back to certain insertionpoint
    wimkees
      Hello,
      In a ID 5.5 javascript I can detect where my current insertionpoint is by using
      ip = app.selection[0].insertionPoints[0].index;
      After doing some textadditions (so my insertionpoint has moved) how can I jump back to that point?
      Any suggestions?
        • 1. Re: Go back to certain insertionpoint
          @wimkees – your insertion point might be moving, but you still have your selection and its first insertion point to get the index from.
          So do not store the index (that is changing every time you are adding or removing text) into a variable.
          Just use the current index the moment you need it:
          //First insertion point of your text selection:
          var ip = app.selection[0].insertionPoints[0];
          //Current index number:
          var ipIndex = ip.index;
          //Add some text at the beginning of your story:
          ip.parentStory.insertionPoints[0].texts[0].contents = "NEW! ";
          //Former index number stored in a variable:
          $.writeln(ipIndex);
          //NOW get the NEW current index number:
          $.writeln(ip.index);
          Uwe
          • 2. Re: Go back to certain insertionpoint
            wimkees Level 1
            Hi Uwe,
            I've to explain my problem better:
            In a document I want to add at my insertionpoint somewhere in a threaded textframe a multipage PDF.
            The pages of the PDF must be placed as inline graphics.
            So my script is:
            Main();
            function Main()
                if (app.selection[0] == null )
                    alert ("Place textcursor first");
                    return;
                var myFile = File.openDialog("Select PDF-file", "");
                app.pdfPlacePreferences.pdfCrop = PDFCrop.cropMedia;
                var currentframe = app.selection[0].parentTextFrames[0];
                var bounds = currentframe.geometricBounds;
            //starting with a frame break
                app.selection[0].contents = SpecialCharacters.frameBreak;
                var myDocument = app.activeDocument;
                var myPage = myDocument.pages.item(0);
                var myFrame = myPage.rectangles.add();
            //now I detect the number of pages of the PDF
            for (var c = 1; ; c++)
                    app.pdfPlacePreferences.pageNumber = c;
                    var newitem = myFrame.place(myFile)[0];
                    newpagenumber = newitem.pdfAttributes.pageNumber;
                    if (c>1 && newpagenumber>1)
                        maxP=newpagenumber;
                    if (c > 1 && newpagenumber == 1 )
                        myFrame.remove();
                        break;
            //here I place a number of framebreaks according to the number of PDF pages
            for (var c = 1;c<=maxP ; c++)
            //here I want to return to my first insertionpoint, place the first PDF-page, skip the following framebreak, add the next PDF-page etc.
                    var myFrame = app.selection[0].rectangles.add();
                    myFrame.geometricBounds = bounds;
                    myFrame.strokeWeight = 0;
                    myFrame.fit(FitOptions.proportionally);
                    myFrame.fit(FitOptions.frameToContent);
            If I execute the script now it tells me there's an invalid object for this request.
            Reason is (I think) there is no frame yet to put the rectangle in.
            • 3. Re: Go back to certain insertionpoint
              @wimkees – I think there are several misconceptions here:
              You assume:
              1. that the text frame you want to place the PDF is
                   1.a is always the same size,
                   1.b never rotated,
                   1.c never skewed
              2. that the story will never be overset
              3. that the PDF that you want to place always has a crop box
              4. that the pages length of the PDF could be determined (not always possible)
              The following snippet is working to place page 1 of a PDF.
              It will not handle an overset story, it assumes that the crop box will work.
              Just to give you something that will actually work.
              Maybe you could wrap it with a loop through all your PDF pages.
              But all four points above must be tackled at a next stage of the script.
              The main idea here is:
              1. Insert two frame breaks in a row
              2. Go back one insertion point just between the two frame breaks
              3. Determine the size of the parent text frame at this point (that will tackle 1.a)
              4. Add the rectangle directly to this insertion point and size it at the same time
              5. Place the PDF to that rectangle
              6. Fit it to the rectangle like you want
              Remember, the following snippet is just a starting point:
              //PlaceFileAtInsertionPoint_1.0.jsx
              //Uwe Laubender
              * @@@BUILDINFO@@@ PlaceFileAtInsertionPoint_1.0.jsx !Version! Sun Mar 31 2013 11:57:48 GMT+0200
              //DESCRIPTION:Places a file at the first insertion point of your selection
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
              //If there is NO file selected, stop the script:
              if(myFile === null){exit();};
              //TO-DO:
              //Here at this point we should have checked, if the selected file is really a PDF file.
              //For testing (and other practical) purposes we should be able to undo the action in one go:
              app.doScript(_PlacePDF_AT_INSERTIONPOINT, ScriptLanguage.JAVASCRIPT, [], UndoModes.ENTIRE_SCRIPT, "Place PDF at Insertion Point");
              function _PlacePDF_AT_INSERTIONPOINT(){
              var myOldPDFCrop = app.pdfPlacePreferences.pdfCrop;
              ip.texts[0].contents = SpecialCharacters.frameBreak;
              //InsertionPoint before:
              var ipToAddRectangle = ip.parentStory.insertionPoints[ipIndex+1];
              var parentTextFrameBounds = ip.parentStory.insertionPoints[ipIndex+1].parentTextFrames[0].geometricBounds;
              var myRectangle = ip.parentStory.insertionPoints[ipIndex+1].rectangles.add({
                  //Important:
                  strokeColor:"None",
                  strokeWeight:0,
                  //Less important:
                  fillColor:"None",
                  //Important:
                  geometricBounds:parentTextFrameBounds
              myRectangle.place(myFile);
              myRectangle.fit(FitOptions.proportionally);
              myRectangle.fit(FitOptions.frameToContent);
              app.pdfPlacePreferences.pdfCrop = myOldPDFCrop;
              //COMMENT:
              //The selection is still the same after execution!
              //So we could use this function theoretically as the ingredients for a loop through all pages of the PDF.
              • 4. Re: Go back to certain insertionpoint
                wimkees Level 1
                Hi Uwe,
                Thx!!! You did solve the problem.
                My script now is:
                // Script to insert PDF-pages (as inline graphics in a text story)
                // Graphic frames in which the PDF-pages are placed are the same size as the text-frame they are in
                // After placing the PDF-page is proportionally scaled and the graphic frame is fit to the PDF-page
                Main();
                function Main()
                // Check if cursor is placed in textframe
                        alert ("Plaats eerst de invoegcursor in een tekstframe");
                        return;
                // Select the PDF-file
                var myFile = File.openDialog("Selecteer het PDF-bestand", "");
                // Use the cropbox of the PDF-file
                // Put the current cursorposition in ip
                // Insert two framebreaks
                // Add a small rectangle to place the PDF-pages in (just for pagedetection)
                    var myFrame = myPage.rectangles.add({geometricBounds:[0, 0, 50, 50]});
                // Here the PDF file is placed in myFrame untill it reaches the end
                // The number of pages is put in variable maxP
                // After that the frame is removed
                            maxP=newpagenumber;
                            myFrame.remove();
                            break;
                // Here is the loop to place the PDF-pages in frames
                for (var c = maxP;c>=1 ; c--)
                                //Important:
                                strokeColor:"None",
                                strokeWeight:0,
                                //Less important:
                                fillColor:"None",
                                //Important:
                        var newitem = myRectangle.place(myFile)[0];
                Only thing that's missing now (but not a big issue): there are no framebreaks after each placed PDF-page. Only after the last one.
                Sorry for putting the script in this message. I don't know how to put it in a frame as you did...
                Thx,
                Wim
                • 5. Re: Go back to certain insertionpoint
                  @Wim – There is a "Use advanced editor" button at the top.
                  Select your code, go to the >> controls and chose Insert / Syntax Highlighting / Java.
                  Uwe
                  • 6. Re: Go back to certain insertionpoint
                    wimkees Level 1
                    @Uwe: See it now.
                    Did some little tweaks to the script.
                    I found out that the recompose() command is important when you insert pages at the end of a story.
                    Here's the (almost?) finally script:
                    Main();
                     function Main()
                            return;
                        myDocument.textPreferences.smartTextReflow = true;
                        myDocument.textPreferences.limitToMasterTextFrames = false;
                        myDocument.textPreferences.deleteEmptyPages = true
                        app.pdfPlacePreferences.pdfCrop = PDFCrop.CROP_PDF;
                    // Use the geometric bounds of the textframe the cursor is in
                    // Insert a framebreak and recompose the document (which is important to do)
                        myDocument.recompose();
                    // Add a small rectangle to place the PDF-pages in (just to detect the number of pages of the PDF)
                        var myFrame = myPage.rectangles.add({geometricBounds:[0, 0, 5, 5]});
                    app.scriptPreferences.enableRedraw = false;
                                maxP=newpagenumber;
                                myFrame.remove();
                                break;
                            var myRectangle = ipToAddRectangle.rectangles.add({
                                    //Important:
                                    strokeColor:"None",
                                    strokeWeight:0,
                                    //Less important:
                                    fillColor:"None",
                                    //Important:
                                    geometricBounds:bounds
                    • 7. Re: Go back to certain insertionpoint
                      Jump_Over Level 5
                      Here's the (almost?) finally script...
                      In case of "almost" I suggest to modify:
                      This one is also true if some pageItem is selected, so the script will fail (i.e. no insertionPoint property for rectangle) and alert omitted.
                      Add a condition like
                      if (app.selection[0]==null || !app.selection[0].hasOwnProperty("alignToBaseline"))
                      to filter selection of texts only.
                      This one could replace some selection (not only insertionPoints are passing alert_statement)
                      Suggest to change it to: ip.contents = SpecialCharacters.frameBreak;
                      By the way: is your intention to start a doc with an empty frame (page)?
                      In case of adding frameBreaks between rectangles insert
                      ipToAddRectangle.contents = SpecialCharacters.frameBreak;
                      in the last line of "for" loop.
                      By the way: current last line seems unnecessary...
                      rgds
                      Jarek
                      • 8. Re: Go back to certain insertionpoint
                        wimkees Level 1
                        @ Jarek
                        Thx for your suggestions. I will implement these (and some lines from Uwe) to my script.
                        @Jarek & Uwe
                        You guys helped me so well!!
                        Maybe you noticed I'm not a programmer but with your help the script works fine now.
                        And I learned a lot more about programming too.
                        Wim
