6 Replies Latest reply on Apr 1, 2013 11:52 AM by mzbik
    Import of mp4(H264/mp3) drops audio track
    mzbik
      (I've searched high and low for answers to this)
      I have an MP4, created via Tivo download, decode, and encoding as MP4 (as above).  Every known player can play it but when I drag it onto Premiere's timeline, the only thing that appears is the video track.
      (Note, the normal Tivo decode produces an MPG bit it has embedded 608/708 captions which Premiere can't handle, so I reencode it to H264, dropping the closed captions).
      Output from MediaInfo:
      General
      Complete name : /Volumes/Macintosh HD 2/Videos/steps/2/x.mp4
      Format : MPEG-4
      Format profile : Base Media
      Codec ID : isom
      File size : 681 MiB
      Duration : 30mn 2s
      Overall bit rate : 3 167 Kbps
      Tagged date : UTC 2013-03-30 22:45:30
      Writing application : Lavf54.61.104
      Video
      Format : AVC
      Format/Info : Advanced Video Codec
      Format profile : High@L4.1
      Format settings, CABAC : Yes
      Format settings, ReFrames : 4 frames
      Codec ID : avc1
      Codec ID/Info : Advanced Video Coding
      Duration : 30mn 2s
      Bit rate : 3 000 Kbps
      Width : 720 pixels
      Height : 480 pixels
      Display aspect ratio : 16:9
      Original display aspect ratio : 16:9
      Frame rate mode : Constant
      Frame rate : 29.970 fps
      Standard : NTSC
      Color space : YUV
      Chroma subsampling : 4:2:0
      Bit depth : 8 bits
      Scan type : Progressive
      Bits/(Pixel*Frame) : 0.290
      Stream size : 652 MiB (96%)
      Writing library : x264 core 128
      Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=24 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=abr / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=50 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
      Audio
      Format : MPEG Audio
      Format version : Version 1
      Format profile : Layer 3
      Mode : Joint stereo
      Mode extension : MS Stereo
      Codec ID : 6B
      Duration : 30mn 1s
      Bit rate mode : Constant
      Bit rate : 128 Kbps
      Channel(s) : 2 channels
      Sampling rate : 48.0 KHz
      Compression mode : Lossy
      Delay relative to video : 67ms
      Stream size : 27.5 MiB (4%)
      Any ideas?
