9 Replies Latest reply: Nov 4, 2007 8:10 AM by Newsgroup_User RSS
    Make "Submit" form button active
    Stephen Pickering122 Community Member
      I have several pages that require a password be typed, then clicking "Submit" to take them to the real page. The Submit button is a Form but I do not know how to make it have "focus" so that one can type the password and hit ENTER key (instead of having to click it with the mouse) to submit the form. I have the code below:
      Thank you for any help!
        • 1. Re: Make "Submit" form button active
          FYI, the code I used is from "encrypted password" from Dynamic Drive.
          • 2. Re: Make "Submit" form button active
            Newsgroup_User Community Member
            .oO(is this taken?)
            >how to make it "active" so that one can type the password and hit ENTER key
            >code below:
            Two things:
            1. The code is invalid. The 'form' element requires an 'action'
            attribute, which points to the server's form processing script. There
            should also be a 'method' attribute to define the form submission method
            (POST would make sense in your case).
            2. Password fields should use the type 'password'.
            3. There's no submit button at all. Try a real one without any JS:
            <input type="submit" value="submit">
            This will work always.
            HTH
            Micha
            • 3. Re: Make &quot;Submit&quot; form button active
              .oO(Michael Fesser)
              >Two things:
              Three of course ...
              Micha
              • 4. Re: Make &quot;Submit&quot; form button active
                Believe it or not, but both the action and method attributes are
                optional. If no action is defined, the same page attempts to process the
                form. If no method is defined, the default is to use GET.
                Having said that, it's better to define both.
                David Powers, Adobe Community Expert
                Author, "The Essential Guide to Dreamweaver CS3" (friends of ED)
                Author, "PHP Solutions" (friends of ED)
                http://foundationphp.com/
                • 5. Re: Make &quot;Submit&quot; form button active
                  .oO(David Powers)
                  >optional.
                  The method is optional, but the action is required.
                  Micha
                  • 6. Re: Make &quot;Submit&quot; form button active
                    quote:
                    Originally posted by: Newsgroup User
                    Two things:
                    Thank you. However because this is for security (as little as it is) my understanding is that I need the js. You're right though, there is no "submit" button at all. So you can see exactly what I working with, here is the example page: http://drywaterweddings.com/couples/testing/testing.html the password is "lastname"
                    How can I use "<input type="submit" value="submit">" Without messing up the rest of the code?
                    Thanks for your help.
                    • 7. Re: Make &quot;Submit&quot; form button active
                      .oO(is this taken?)
                      JS doesn't do any good for security. It can't protect anything. In fact
                      your current script is just "security by obscurity", which will always
                      fail sooner or later.
                      >"lastname"
                      Ugly script. What if you want to add more users and passwords one day?
                      And do you really mean "Java" as mentioned on the page? Or shouldn't
                      that be "JavaScript" instead, which is an entirely different thing?
                      >rest of the code?
                      I strongly suggest to drop that useless script, use a simple proper form
                      and a server-side script to validate the password(s).
                      Micha
                      • 8. Re: Make &quot;Submit&quot; form button active
                        Yes, you're right. Confusingly, although action is required, it can take
                        an empty string (action=""). When this happens, the page attempts to
                        process the form itself, a common scenario with both client-side and
                        server-side scripts.
                        • 9. Re: Make &quot;Submit&quot; form button active
                          .oO(David Powers)
                          Correct. Even an empty URL is completely valid (same-document
                          reference).
                          But I can remember a problem with empty URLs in the action attribute
                          some years ago. I'm not sure which browser it was, IIRC it was an old
                          Lynx. The problem was, that the browser didn't resolve the empty URL
                          correctly to the URL of the current document, but to the _directory_ of
                          that document, which was entirely wrong of course.
                          Since then I've never used empty action attributes again, I always
                          specify the (relative) URL to the script, even if it's the same page.
                          Micha
