3 Replies Latest reply on Mar 31, 2013 7:00 AM by kglad
    I'm stuck with making drop down menu.
    solish12
      Hello everyone.
      I'm making drop down menu follwing these tutorials https://www.youtube.com/watch?v=xE7hPe8KFVw
      But after typing code it doesn't work. (The tutorial is AS3 but I have to use AS2 due to my uni project.)
      The code I typed is ;
      import fl.transitions.Tween;
      import fl.transitions.easing.Regular;
      import fl.transitions.easing.Elastic;
      stop();
      menu_con.korea_rect.visible = false;
      menu_con.korea_btn.addEventListener(MouseEvent.MOUSE_OVER, koreaMouseOver);
      menu_con.korea_rect.addEventListener(MouseEvent.MOUSE_OUT, koreaMouseOut);
      function koreaMouseOver(event:MouseEvent):Void{
          var koreaSubTween:Tween = new Tween(menu_con.korea_sub, "y", Regular.easeOut, menu_con.korea_sub.x, 175, .5, true);
      function koreaMouseOut(event:MouseEvent):Void{
              var koreaSubTween2:Tween = new Tween(menu_con.korea_sub, "y", Regular.easeOut, menu_con.korea_sub.x, 24.5, .5, true);
      But 'stop' didn't work so it's still visible, and the code doesn't work at all.
      Does anyone know any solutions including making drop down menu different way.
        • 1. Re: I'm stuck with making drop down menu.
          except for your Void x2, that's not as2 code so, if you're publishing for as2, it's not going to work.
          as2 would look like:
          stop();
          menu_con.korea_rect._visible = false;
          menu_con.korea_btn.onMouseOver=koreaMouseOver;
          menu_con.korea_rect.onMouseOut=koreaMouseOut);
          function koreaMouseOver():Void{
              var koreaSubTween:Tween = new Tween(menu_con.korea_sub, "_y", Regular.easeOut, menu_con.korea_sub._x, 175, .5, true);
          function koreaMouseOut():Void{
                  var koreaSubTween2:Tween = new Tween(menu_con.korea_sub, "_y", Regular.easeOut, menu_con.korea_sub._x, 24.5, .5, true);
          • 2. Re: I'm stuck with making drop down menu.
            solish12 Level 1
            It's still not working....
            I even don't know what I've done wrong.
            Thanks for the reply though.
            • 3. Re: I'm stuck with making drop down menu.
              oops, use:
              stop();
              menu_con.korea_btn.onRollOver=koreaMouseOver;
              menu_con.korea_rect.onRollOut=koreaMouseOut;
