1 Reply Latest reply on Nov 4, 2007 6:56 AM by jbbmovil
    Import Mathematical Libraries
      I'm new to programming with ActionScript and I'm trying to develop a Physics Tutorial on Flash.
      As Java is quite new for me, I found some free libraries in the Web which have all the mathematical functions that I need, and I'm trying to learn how to use them from Flash Professional 8.
      To avoid any self-made mistakes I copied an example and tried to run it, but it gives me sintax errors from the beggining...
      I'm placing all the libraries in a subdirectory hanging from the directory where I save the .fla file: I guess that this is what the help file calls the working_directory: \org\spaceroots\mantissa\ode
      But it seems that the IMPORT statement is not correct: it tells me that the function is not loaded as follows:
      **Error** Scene=Scene 2, layer=Acciones, frame=1:Line 9: Attribute used outside class.
      public class ODEExample implements FirstOrderDifferentialEquations
      **Error** Scene=Scene 2, layer=Acciones, frame=1:Line 10: The class or interface 'org.spaceroots.mantissa.ode.FirstOrderDifferentialEquations' could not be loaded.
      Is this where I should copy the downloaded libraries? Or does the problem come from some other thing that I don't see ?
      Any help would be appreciated.
      Thanks in advance,
      Attached the complete code:
        • 1. Re: Import Mathematical Libraries
          jbbmovil Level 1
          Clearly a novice mistake: I was trying to import the libraries as ".java" files, simply renaming them as ".as" and it does load them... producing many more errors, I guess that due to differences between JAVA and ActionScript.
          I leave the message just in case it is of help to any novice as me.
          Thanks any way,
