4 Replies Latest reply on Apr 8, 2013 11:55 PM by Muthuraj Durairaj
    find and remove text frames with same geometricBounds
    foredit
      Hi Scripter ...new question starting from here:
      var mySelection = app.activeDocument.selection[0].geometricBounds;
      //alert (mySelection);
      everywhere in the document i need to find and remove text frames with the same geometricBounds.
      If possible, same dimensions but not same positions.
      Thanks for help!
        • 1. Re: find and remove text frames with same geometricBounds
          R-Bala-Krishnan Level 2
          According to my understanding, frame which having the equal widthxheight need to be remove, sorry if it’s not match your requirement.
          var myWidth = Number(mySelection[3]-mySelection[1]);
          var myHeight = Number(mySelection[2]-mySelection[0]);
          var allFrames = app.activeDocument.allPageItems;
          while(t = allFrames.pop() ) {
              if(t.isValid){
                  var myTextframe = t.geometricBounds;
                  var myTWidth = Number(myTextframe[3]-myTextframe[1]);
                  var myTHeight = Number(myTextframe[2]-myTextframe[0]);
                  if((myWidth == myTWidth) && (myHeight == myTHeight)){
                      t.remove();
          Regards,
          Bala
          • 2. Re: find and remove text frames with same geometricBounds
            foredit Level 1
            Thanks Bala, this is exactly what i mean ...but testing the script (indesign cs6) something is going wrong.
            Not all frames (with same dimensions) are removed.
            Have a better situation using "parseInt" instead of "Number".
            I would join my indesign test document but don't know how.
            Anyway, this is great for me, good to work around
            best regards
            • 3. Re: find and remove text frames with same geometricBounds
              foredit Level 1
              ok Bala ...due to decimal differences some frames weren't removed.
              I solved with "Math.round" in place of "Number"
              var myWidth = Math.round(mySelection[3]-mySelection[1]);
              var myHeight = Math.round(mySelection[2]-mySelection[0]); alert(myHeight);
                  if(t.isValid){
                      var myTWidth = Math.round(myTextframe[3]-myTextframe[1]);
                      var myTHeight = Math.round(myTextframe[2]-myTextframe[0]);
                          t.remove();
              Now your script works fine!
              Thanks a lot!
              • 4. Re: find and remove text frames with same geometricBounds
                Muthuraj Durairaj
                I am trying to find and move text frames from one position to another. Below is the code I tried. I am using Indesign CS6, and nothing happened when this script was running. Can you please help me on this. Thanks.
                var oldposition = [216.425, 103.89] // original position, upper left corner
                var newposition = [216.425, 54] // new position, upper left corner
                //var threshold = new UnitValue(1,"pt"); // threshold value
                var myFrame = app.activeDocument.textFrames.everyItem().getElements();
                for (var i=0; i<myFrame.length; i++){
                //    if (Math.abs(myFrame[i].geometricBounds[1]-oldposition[0])<threshold &&Math.abs(myFrame[i].geometricBounds[0]-oldposition[1])<threshold ){
                if (Math.round(myFrame[i].geometricBounds[1])==oldposition[0]&&Math.round(myFrame[i].geometr icBounds[0])==oldposition[1]){
                    myFrame[i].move(newposition);
