2 Replies Latest reply on Apr 2, 2013 7:49 AM by RossRaphael
    Syntax for a form posting to a post handler
    RossRaphael
      So I have a component with a component JSP that contains :
      <form id="flagMessage" name="flagMessage" method="POST" action="/post.POST.html">
         <input type="textarea" name="reason" rows="4" cols="50"/><br>
         <input type="submit" value="Submit"/>
         <input type="button" value="Cancel" onclick="$CQ('#<%=id%>-flag-form').toggle()"/>
      </form>
      then I have a post handler in the component at /actions/post.POST.jsp
      I end up getting a 500 where it complains about the property reason, referring to my textarea. A log statement in my handler never gets written to the log. I haven't had to do something like this in a long time and I know its something small that I am missing, but I couldn't put my finger on it.
        • 1. Re: Syntax for a form posting to a post handler
          pchamoun Level 1
          The following example shows how to do a post and a get. You can use this example as a base for any simple tool you want to implement in CQ.
          Here is how I would do it:
          1- Create a node (/apps/tools/components/FormPosting) of type sling:Folder
          2- Create an html.jsp under FormPosting and type the following code in it:
          <%@include file="/libs/foundation/global.jsp"%>
          <sling:defineObjects /><html><head><title>Form Posting Example</title></head><body>
          <cq:include script="form.jsp" />
          </body>
          </html>
          3- Create an form.jsp under FormPosting and type the following code in it:
          <%@taglib prefix="sling" uri="http://sling.apache.org/taglibs/sling/1.0"%>
          <%@taglib prefix="cq" uri="http://www.day.com/taglibs/cq/1.0"%>
          <cq:defineObjects />
          <html>
          <head>
          <meta http-equiv="Content-Type" content="text/html; utf-8" />
          <script src="/libs/cq/ui/resources/cq-ui.js" type="text/javascript"></script>
              function submitform(){
                  var paths = document.formposting.pathList.value;
                  if(paths.length == 0){
                      alert("List can not be empty");
                      return;
                  document.formposting.submit();
              </script>
          </head>
          <br />
          <form name="formposting" method="post"></br>
          Enter list of paths (Here please don't give base path)<b>
          <font color="red">*</font></b>: </br>
          <TEXTAREA NAME="pathList" id="pathList" ROWS="5" COLS="50"></TEXTAREA> <br></br>
          Name: <input type="text" name="name" id="name">MyPackage.zip</input></br>
          Group: <input type="text" name="someGroup" id="group">MyPackageGroup</input></br>
          <input type="button" value="Post" onclick="javascript:submitform()" />
          </form>
          </html>
          4- Create an html.jsp under FormPosting and type the following code in it:
          <%@page session="false" import="javax.jcr.*,
                  com.day.cq.wcm.api.Page,
                  com.day.cq.wcm.api.PageManager,
                  org.apache.sling.api.resource.Resource,
                  java.io.PrintWriter,
                  javax.servlet.jsp.JspWriter" %>
          <%@page import="org.osgi.framework.BundleContext"%>
          <html>
          <head><title>Form Positing Example</title></head>
          <body>
          Session sess = resourceResolver.adaptTo(Session.class);
          BundleContext bundleContext = sling.getService(BundleContext.class);
          // Get stuff from the bundleContext
          String pathList = request.getParameter("pathList");
          String name = request.getParameter("name");
          String someGroup= request.getParameter("someGroup");
          String[] paths = pathList.split(",");
          out.println("<br> Adding following path:");
          for(int i=0;i<paths.length;i++) {
               out.println("<br><font color=red>"+paths[i]+"</font>");
          String serverName = (request.getProtocol().split("/")[0]).toLowerCase()+"://"+request.getServerName();
          if(!"".equals(request.getServerPort())){
              serverName+=":"+request.getServerPort();
          String docroot = serverName +"/crx/packmgr/service.jsp";
          out.println("<br><br><strong>Name is: "+ name+"</strong>");
          out.println("<br><br><strong>Group is: "+ name+"</strong>");
          <form method="get" action="<%=docroot %>">
          <input type="hidden" name="cmd" id="cmd" value="get"></input>
          <input type="hidden" name="name" id="name" value="<%=Text.escape(name) %>"></input>
          <input type="hidden" name="group" id="group" value="<%=Text.escape(someGroup) %>"></input>
          <input type="submit" value="Download Package"></input>
          </form>
          </body>
          </html>
          5- Create the following nt:unstructured node (/apps/tools/components/FormPosting/run) with sling resourceType = /apps/tools/components/FormPosting
          6- To test go to (http://localhost:4502/apps/tools/components/FormPosting/run.html). If you have a package in some group then type the name and the group it blongs to and then do the test.
          • 2. Re: Syntax for a form posting to a post handler
            RossRaphael Level 1
            Here is the outcome I came up with
            <form id="flagMessage" name="flagMessage" method="POST" action="<%= resource.getPath() %>.html>
            And I placed POST.jsp in the same directory adjacent to my component JSP, which has worked.
