6 Replies Latest reply on Apr 2, 2013 1:21 PM by Aubreyff
    Layer > Type > Replace All Missing Fonts with jsx.
    Aubreyff Level 1
      Hi All,
      I am trying to use the Layer > Type > Replace All Missing Fonts command from a jsx script. Is it possible?
      Thank you,
      Aubrey
        • 1. Re: Layer > Type > Replace All Missing Fonts with jsx.
          c.pfaffenbichler Level 9
          Does ScriptingListener.plugin record any code for this?
          • 2. Re: Layer > Type > Replace All Missing Fonts with jsx.
            Paul Riggott Level 6
            If there is no scriptlistner output you could try recording an action and use Insert Menu Item from the action palette fly-out menu, this hopefully should generate some code.
            • 3. Re: Layer > Type > Replace All Missing Fonts with jsx.
              Aubreyff Level 1
              Thank you both, very much. This forum is very helpful.
              • 4. Re: Layer > Type > Replace All Missing Fonts with jsx.
                xbytor2 Level 4
                If you really do need to call a menu item in JS that doesn't generate listener code, here's how
                I do it.
                1) Create an action with a single step, the Insert Menu Item bit.
                2) Run ActionToXML.jsx from xtools. You'll end up with a file that looks like this:
                <ActionFile key="MenuItem.atn" file="/private/var/folders/gj/t92cwx212c9gdvhl_8xh5qc80000gn/T/TemporaryItems/MenuItem.atn">
                  <ActionSet version="16" name="MenuItem" expanded="false" count="1">
                    <Action key="1" name="MenuItem" expanded="false" count="1">
                      <ActionItem key="TEXT" expanded="false" enabled="true" withDialog="false" dialogOptions="3" identifier="TEXT" event="select" name="Select" hasDescriptor="true">
                        <ActionDescriptor key="select" count="1">
                          <DescValueType.REFERENCETYPE key="1853189228" id="1853189228" symname="Null" sym="null">
                            <ActionReference key="1853189228" Id="1853189228" symname="Null" sym="null" count="1">
                              <ReferenceFormType.ENUMERATED key="1299062816" id="1299062816" symname="MenuItem" sym="Mn  " desiredClassString="MenuItem" desiredClass="Mn  " enumeratedTypeString="MenuItem" enumeratedType="MnIt" enumeratedValueString="ToggleInfoPalette" enumeratedValue="TglI"/>
                            </Actionreference>
                          </DescValueType.REFERENCETYPE>
                        </ActionDescriptor>
                      </ActionItem>
                    </Action>
                  </ActionSet>
                </ActionFile>
                3) The part that you need is the ID for the menu item. It is the enumeratedValue attribute of ReferenceFormType.ENUMERATED. In this case it's 'TglI' for Windows->Info which toggles the Info palette.
                4) Here's code for calling a menu item.
                function doMenuItem(itemID, interactive) {
                  function cTID(s) { return app.charIDToTypeID(s); };
                  function sTID(s) { return app.stringIDToTypeID(s); };
                  var desc = new ActionDescriptor();
                  var ref = new ActionReference();
                  ref.putEnumerated(cTID("Mn  "), cTID("MnIt"), itemID);
                  desc.putReference(cTID("null"), ref);
                  var lvl = $.level;
                  $.level = 0;
                  try {
                    var mode = (interactive != true ? DialogModes.NO : DialogModes.ALL);
                    executeAction(sTID("select"), desc, mode);
                  } catch (e) {
                    $.level = lvl;
                    if (e.number != 8007) { // if not "User cancelled"
                      throw e;
                    } else {
                      return false;
                  $.level = lvl;
                  return true;
                5) The code to invoke the menu item in question would look like this:
                doMenuItem('TglI');
                • 5. Re: Layer > Type > Replace All Missing Fonts with jsx.
                  Michael L Hale Level 5
                  Newer versions of Photoshop have an app method for running menu items.
                  app.runMenuItem();
                  • 6. Re: Layer > Type > Replace All Missing Fonts with jsx.
                    Aubreyff Level 1
                    I was able to use ScriptingListener.plugin.
                    I opened a file with missing fonts and ran Layer > Type > Replace All Missing Fonts.
                    In the ScriptingListener.log was this code.
                    var idreplaceSubstitutes = stringIDToTypeID( "replaceSubstitutes" );
                    executeAction( idreplaceSubstitutes, undefined, DialogModes.NO );
                    It seems to have worked.
