2 Replies Latest reply on Apr 17, 2013 10:33 AM by Naveeth_J
    Workflow data transfer from one process to another process
    Naveeth_J Level 1
      We recently upgraded to CQ 5.6, and the data sharing between workflow process is not working properly, it was working fine with 5.4 version. Please check the snippet below
      workItem.getWorkflowData().getMetaDataMap().put("test", "data transfer between processes");
      doesn't seems to get populated.
      Digging deep into it, we found that the implementation has been changed with a wrapper CQWorkflowDataWrapper, which returns newly instantiated map each time
      public MetaDataMap getMetaDataMap()
              return new CQMetaDataMap(graniteData.getMetaDataMap());
      With CQ 5.4, we get the following
      String test =workItem.getWorkflowData().getMetaDataMap().get("test");
      However, in CQ 5.6, the String test value is null...as the map was not populated.
      Is there any other way to pass the desired result(any object) from one process to other process?
