• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Unable to complete installation...
New Here ,
Apr 01, 2013 Apr 01, 2013
I have tried to install Flash Player with no success.  I am running a Windws 7, Internet Explorer 10, 32/64 bit systerm. When the program gets to about 50% installed, it tells me to turn off the Internet Explorer even though it is not turned on.  I have tried several  times using the 64bit and the 32bit IE - no success.  I used to have the Flash player and my Secunia says I DO hve it but it does not open when I try to open an American Greetings card.
Please help....
Eleanor K
Views
681
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Apr 02, 2013 Apr 02, 2013
You need to close Internet Explorer for installation to continue.
If it doesn't, please press Control , Alt , and Delete keys together. Select Task Manager and go to the Process tab.
See if you have any process of Internet Explorer. If you see, select it and click End Process.
Also, go to the following page and let us know if you see the animation. http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
Sunil
Votes
Translate
Translate
Report
Report
New Here ,
I followed the instructions to delete processes and was able to
get the files installed. However, it still does not recognize
it as I again tried to open an e-card from American Greetings
and it tells me I need to install it.
In checking what I have (deleting the cache, etc) I read I do
nothave the "plug-in" version. Do I need that?
Another 'symptom' that might interest you, I have to copy the
link shortcut on the Internet Explorer most times rather than
just click the link and get results.
So, I still can't access the program when needed.
Eleanor
Votes
Translate
Translate
Report
Report
LEGEND ,
Apr 03, 2013 Apr 03, 2013
For Internet Explorer check
You don't need the plugin if you only use Internet Explorer; the plugin is for other browsers like Firefox.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks - I did finally get to see the Easter card; however3r, I
could not close the page. The "x" did not work, in fact it's
still open as I have not engaged the task manager. I am using
IE 10 which came to me as aWindows Update. And, I would not
allow Google Chrome to download with the Flash Player. I think
there are gremlins. But, thanks to the info about the "gear" as
I can access that easily. I may find it to my advantage to go
back to IE 9 r 8. It gets to be a bother to not be able to
click links and "go." Time will tell. Thanks again!
Eleanor
Votes
Translate
Translate
Report
Report
