7 Replies Latest reply on Apr 12, 2013 5:28 PM by Mandy_Wiesener
    Changing dropdown fill colour on selection.
    Imgoodtogo
      I am using Livecycle ES3. I have a script that is changing the fill colour dependent on what is selected in the dropdown. This is working fine for me in Acrobat X Pro but doesn't seem to work in earlier versions.
      Is there something else I can do that it works in all versions, the form is saved to be compatible to version 7 and my target version is set to version 9.0 or later.
      This is my script on the 'exit' event (thank you Assure Dynamics):
      var vName = this.somExpression;
      var fieldObj = xfa.resolveNode(vName + ".ui.#choiceList.border.fill.color");
      if (this.rawValue == "Ahead of Schedule") {
          fieldObj.value = "51,102,255";
      else if (this.rawValue == "Progressing Well") {
          fieldObj.value = "0,196,0";
      else if (this.rawValue == "Requires Attention") {
          fieldObj.value = "255,255,0";
      else if (this.rawValue == "Requires Immediate Attention") {
          fieldObj.value = "255,0,0";
      else {
          fieldObj.value = "255,255,255";
      Thanks for any help out there.
        • 1. Re: Changing dropdown fill colour on selection.
          Mandy_Wiesener Level 3
          you have to do the following:
          Use the change-event, xfa.event.newText instead of this.rawValue..and it works fine.
          You can use the following script:
          switch(xfa.event.newText)
              case "example1":
              xfa.resolveNode("DropdownListe1.ui.#choiceList.border.fill.color").value = "0,255,0";
              break;
              case "example2":
              xfa.resolveNode("DropdownListe1.ui.#choiceList.border.fill.color").value = "12,45,133";
              break;
              case "example3":
              xfa.resolveNode("DropdownListe1.ui.#choiceList.border.fill.color").value = "134,255,0";
              break;
          // OR YOUR SHORTER ONE
              case "example1":
              fieldObj.value = "0,255,0";
              break;
              case "example2":
              fieldObj.value = "12,45,133";
              break;
              case "example3":
              fieldObj.value = "134,255,0";
              break;
          Hope it will helps you,
          Mandy
          • 2. Re: Changing dropdown fill colour on selection.
            Imgoodtogo Level 1
            Thanks very much for your reply. I tried this method and my results were varied. The fill colour didn't always change.
            The script I used worked perfectly fine, it just won't work correctly in versions prior to Acrobat X. Many of the people I work with are still using Acrobat 9 either Pro or Standard and it is not working well for them. Sometimes it only changes the colour when the field is clicked in and sometimes not at all.
            Is there anything I can do about this?
            • 3. Re: Changing dropdown fill colour on selection.
              Yes, you have to set the follwoing parameter.
              1. Got to File
              2. Form Properties
              3. Defaults
              4. Choose Target Version
              5. Select your choice
              This is the screenshot for ES 3.
              And below the screenshot for ES2 (in german , Standard = Default; Zielversion = Target version)
              Then take a look by "windows" | "info" and "report". If you got some error messages there it could be that some methods not supported by an earliere version. If you don't got a error message everythin should works fine.
              Sorry for my english. I hope you understand me.
              Kind regards Mandy
              • 4. Re: Changing dropdown fill colour on selection.
                Imgoodtogo Level 1
                My form is set for target version 9.0 and later and the compatibility is set to version 7
                I think I am going to change tactics and use show/hide a field instead.
                I do appreciate your help and certainly, if you have any other suggestions I would really like to know.
                • 5. Re: Changing dropdown fill colour on selection.
                  "Info" and "reports" shows no error messages. It have o work correct.
                  Maybe this script is ok but another script in your form is not compatible and produce the error?
                  You could upload your form anywhere?
                  Then I can take a look.
                  Mandy
                  • 6. Re: Changing dropdown fill colour on selection.
                    Imgoodtogo Level 1
                    The form doesn't have any other scripts actually except for one simple show/hide based on a radio button selection.
                    I would be happy to share the form anyway but am not sure where to upload it?!
                    • 7. Re: Changing dropdown fill colour on selection.
                      You could register yourself by Adobe Workspaces. https://workspaces.acrobat.com/app.html#o for free.
                      There you can upload your form.
                      Kind regards Mandy
