2 Replies Latest reply on Apr 2, 2013 12:57 PM by JavaNovice
    DateTime Calculation
    JavaNovice Level 1
      Hello.  I have a form in Adobe Acrobat X that has 2 date/time fields.  The script below is being used to calculate the difference in hours between the two fields.  Is there a way to get the result to show the minutes as time?  For example, if the difference is 8hrs and 15min the result shows 8.25 instead of 8:15.  Is there any way to have it return as 8:15?  Thank you for any help!  Here is the script currently being used:
        • 1. Re: DateTime Calculation
          Duplicate post http://forums.adobe.com/message/5199749#5199749
          A nice feature of Acrobat forms is that the displayed format does not need to match the field value. So you can created a custom format script to convert the hours to HH:MM. This feature will allow one to accumulate all the elapsed times for a subtotal, total or grand total in hours but display the intervals various total in hours and minutes.
          Since this formatting could be repeated several times using a document level script for the conversion will cut down on the amount of code that needs to be entered and debugged.
          // document level script to convert Hours to HH;MM format
          function Num2Time(nHours) {
          if(nHours == 0) return ""; // 0 hours is a null srting
          else return util.printf("%,201.0f:%,102.0f", Math.floor(nHours), (nHours * 60) % 60);
          } // end Num2Time
          // end document level script
          // custom format script
          event.value = Num2Time(event.value);
          // end custom format script.
          • 2. Re: DateTime Calculation
            JavaNovice Level 1
            You are so awesome!
            I apologize for the double post...I realized too late that I originally put my question in the wrong forum.
            Thank you so much!
