1 Reply Latest reply on Apr 2, 2013 3:45 PM by Navdeep Sethi
    How to order Standard HTTP Filter as OSGI components
    Navdeep Sethi
      I have an issue where I would like to order 2 standard filters deployed as OSGI components on Adobe CQ5.5 - Apache Felix console - so that filter A should run first and filter B should run second in the sequence. Do you know if there is any OSGI or SCR property which can order 2 filters in sequence so that one should run after another?
      For example:
      Filter A
      @Component
      @Service @org.apache.felix.scr.annotations.Properties({
               @Property(name = "pattern", value = "/.*"),
              @Property(name = Constants.SERVICE_RANKING, intValue = 99999, propertyPrivate = false)
      public class FilterA implements implements javax.servlet.Filter  { }
      FilterB
      @Component
              @Property(name = Constants.SERVICE_RANKING, intValue = 100000, propertyPrivate = false)
      public class FilterB implements implements javax.servlet.Filter  { }
      I would like to run FilterA first and then FilterB. If I deploy the above filters as OSGI bundle on CQ5.5 then I only see FilterB is registered on the HTTP White board console. I do not see FilterA being even registered on Http White board or being invoked in request flow. Thanks.
