2 Replies Latest reply on Apr 3, 2013 2:01 PM by sasteck
    Windows tells me I'm missing flash.ocx
    sasteck
      Adobe tells me I installed Flash Player successfully but when I try to run a program that uses Flash Player it tells me I need to install it. Windows problem solver tells me I'm missing flash.ocx. How do I get it?
        • 1. Re: Windows tells me I'm missing flash.ocx
          pwillener Level 8
          What program uses flash.ocx?  That is a very old Flash Player version.
          What I would do if I needed flash.ocx is to copy the latest Flash32_11_6_602_180.ocx, then rename the copied file to flash.ocx
          You would find that file
          • on 32-bit Windows in C:\WINDOWS\system32\Macromed\Flash
          • on 64-bit Windows in C:\WINDOWS\syswow64\Macromed\Flash
          • 2. Re: Windows tells me I'm missing flash.ocx
            sasteck Level 1
            First of all I want to thank you very much for your response to my
            problem. But, as a result I'm now wondering if my real problem might
            be the absence of the file you suggested I copy and rename. The only 2
            files that came even close to the name you indicated were
            FlashPlayerPlugin_11_6_602_180 and FlashUtil32_11_6_602_180_Plugin,
            both listed as applications. Given that there was no *.ocx file I was
            thinking maybe the Windows solution utility may have given an outdated
            name and may be referencing the file you named. However, I have
            deleted and downloaded the Flash Player program numerous times and I
            can't help but wonder why no *.ocx file appears after Adobe tells me
            the installation was successful.
            Do you have any more suggestions I might try to correct this? Any
            assistance would be appreciated.
            Steve Steck
            Quoting Pat Willener <forums_noreply@adobe.com>:
            Pat Willener http://forums.adobe.com/people/pwillener created the
            discussion
            "Re: Windows tells me I'm missing flash.ocx"
            To view the discussion, visit:
            http://forums.adobe.com/message/5201717#5201717
