6 Replies Latest reply on Nov 5, 2007 3:27 PM by heathrowe
    Problem with Spry Gallery Thumbnails
    LesMizzell
      Reference: http://www.columbiacityjazz.com/index.cfm?action=cmf.jazz%20dance%20photos
      Regardless of what I check when creating an album, it's using the main images as the thumbnails - not the actual thumbnails defined in the "thumbs" directory.
      This is a problem for two reasons - first, it's going to load all the full size images to the page as soon as the page opens, which can get darned slow if there's a lot of them. Second, my thumbnails are often *not* small versions of the full image, but maybe just a small part of the main image.
      in my XML file - the default seems to be
      path='myPICS' hasThumb='false' thumbSrc=''
      If I change this to:
      path='myPICS' hasThumb='true' thumbSrc='thumbs'
      or
      path='myPICS' hasThumb='true' thumbSrc='myPICS/thumbs'
      ...I still get the full size image used as the thumbnail.
      Any ideas?
        • 1. Re: Problem with Spry Gallery Thumbnails
          heathrowe Most Valuable Participant
          In the Export Options tab/pane of the script do you have Export Thumbnails ticked?
          h
          • 2. Re: Problem with Spry Gallery Thumbnails
            ok - I just ran a few tests and sure enough, you are correct - the end result is that the thumbs point to the SAME full version images.
            Feel free to submit a bug report here
            http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
            h
            • 3. Re: Problem with Spry Gallery Thumbnails
              LesMizzell Level 1
              So where in the generated code can I change the path so the thumbnails are used? I've already made a lot of alterations to customize it to my needs, but so far, haven't been able to trace down exactly where I could redefine the path.
              • 4. Problem with Spry Gallery Thumbnails
                Open up slideshow.xml (in your fav editor)
                1. where the thumbSrc='', now change it to thumbSrc='thumbs'
                2. you can leave hasThumb='false' because for some reason it is not being utilized, that I can figure out.
                3. Save the changes
                Open up the index.html file (in your fav editor)
                1. locate the thumbnails div and change what I have bolded
                <div spry:repeat="dsSlides" onclick="HandleThumbnailClick('{ds_RowID}');" onmouseover="GrowThumbnail(this.getElementsByTagName('img')[0], '{@thumbWidth}', '{@thumbHeight}');" onmouseout="ShrinkThumbnail(this.getElementsByTagName('img')[0]);"> <img id="tn{ds_RowID}" alt="thumbnail for {@src}" src="{dsAlbums::@path}/{@src}" width="24" height="24" style="left: 0px; right: 0px;" /> </div>
                To
                <div spry:repeat="dsSlides" onclick="HandleThumbnailClick('{ds_RowID}');" onmouseover="GrowThumbnail(this.getElementsByTagName('img')[0], '{@thumbWidth}', '{@thumbHeight}');" onmouseout="ShrinkThumbnail(this.getElementsByTagName('img')[0]);"> <img id="tn{ds_RowID}" alt="thumbnail for {@src}" src="{dsAlbums::@path}/{dsAlbums::@thumbSrc}/{@src}" width="24" height="24" style="left: 0px; right: 0px;" /> </div>
                In sum, for the above code block, change the source (src) tag block to
                hope this helps
                let me know
                h
                • 5. Re: Problem with Spry Gallery Thumbnails
                  LesMizzell Level 1
                  h
                  Ok, that did the trick - as long as you edit your XML file for each album as well:
                  Thanks so much for your help!
                  After al that, I'm thinking this may not be the best way to go for a photo album though. It looks nice, but I'm concerned that I see no way for the images to ever be indexed by the search engines (correct me if I'm wrong).
                  • 6. Re: Problem with Spry Gallery Thumbnails
                    No problem
                    It's not 100% perfect, and as you pointed out, the Fw script needs correction, yet alone updating, Spry itself is updated and improved to 1.6 now - http://labs.adobe.com/technologies/spry/home.html. I believe, like all other Ajax solutions, you may still have the issue of search engine indexing.
                    h
