• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Conflicting Information
Guest
Apr 03, 2013 Apr 03, 2013
I'm a Information Security Analyst and currently I'm trying to strengthen our ColdFusion hardening standards and I have an issue that I need to understand.
I'm referencing two separate Adobe documents,
First document:
ColdFusion 9 Lockdown Guide
Recommends:
Page 16 of 35.  Do not enable RDS. Click next...
Next document:
Security Advisory for ColdFusion
Release date: January 4, 2013
Last updated: January 16, 2013
Vulnerability identifier: APSA13-01
Recommends:
  • Setting the password for Remote Development Services (even if RDS is disabled)
  • Enabling password protection for RDS
  • Setting the Admin password and enabling password protection for Administrator
So, Adobe recommends, 1st, not to Enable RDS at all, but then recommends as a "mitigation", Enabling RDS (post installation) to setup a username and password, but the ColdFusion 9 Lockdown Guide "Do not enable RDS.".
Maybe as a "Remediation", Adobe should just remove RDS since a) they recommend keeping it disabled and b) it's such a vulnerability?  Also, I would suggest that the recommendations from the Security Advisory (s) be incorporated into an updated ColdFusion 9 Lockdown Guide.
I'm sure this cannot be the first time they've heard this.
Don
Views
729
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
It doesn't say to "Enable RDS", it says "Enable password protection for RDS"
You can disable the RDS by commenting out the servlet mapping in web.xml, but you should still set passwords for RDS on the chance that it ever gets enabled on the server (someone restores the wrong XMl files or something). It is best to enable separate RDS usernames and passwords for this.
You should still keep RDS disabled in production, but this is an example of defense-in-depth. Even if RDS were to become enabled, it would alteast be password protected. These documents do not contradict each other.
Disabling RDS: http://helpx.adobe.com/coldfusion/kb/disabling-enabling-coldfusion-rds-production.html
Jason
Votes
Translate
Translate
Report
Report
Guest
Can usernames and passwords be setup\configured without enabling RDS?
Votes
Translate
Translate
Report
Report
Advocate ,
Yes
jason
Votes
Translate
Translate
Report
Report
Guest
Hi Jackson ,
Security Advisory says " Enable Password protection for RDS " and not to " Enable RDS " . We Recommend to Set a unique password for RDS and then Disable RDS for Production Environment .
After the latest security hotfix ASPB 13-03 released on Jan 15th , You can Disable and Enable RDS in the administrator UI itself .
Navigate to Security -> RDS
Turn on the Enable RDS Service ( So that you can set a unique password )
Set the Password
Turn off the Enable RDS Service
Regards ,
YASHAS RATTEHALLI
ADOBE ColdFusion Team
Votes
Translate
Translate
Report
Report
Guest
Apr 04, 2013 Apr 04, 2013
LATEST
The above mentioned steps are precautionary measures which you need to follow to prevent any potential hacks . However you are quite safe in production environment even if just RDS is disabled ( If your server is fully patched ) .
Regards ,
YASHAS RATTEHALLI
Votes
Translate
Translate
Report
Report
Resources
Documentation
