1 Reply Latest reply on Apr 3, 2013 11:02 AM by Genevieve Laroche
    Editing "Submission-Enabled PDF"
      Is there a way to edit the "Submission-Enabled PDF" in Acrobat to make the docment 508 compliant?  So far I recieve a warning sign stating that the PDF is a secured document and that editing is not permitted.
        • 1. Re: Editing "Submission-Enabled PDF"
          Genevieve Laroche Adobe Employee
          In Acrobat :
          1) Open the form
          2) File > Save a copy...
          3) Open the copy just saved
          4) Make your changes to the PDF
          5) Save as Other > Reader Extended PDF > Enable More Tools (includes form fill-in and save)...
          FormsCentral saves a Reader Extended PDF by default so that the PDF can be filled out and saved in Adobe Reader. This has the side effect to lock the PDF from editing. The "Save a Copy" removes the Reader Extension and allows you to modify the PDF.
          Note that some changes might break the FormsCentral workflow.
