1 Reply Latest reply on Apr 4, 2013 8:11 AM by David W. Goodrich
    BEGINNER_X Level 3
      Hi All,
      Job is in single column.
      But Footnote flow with reference number at the bottom of every page using Document Footnote options and word doc file.   //working fine
      My question, is it possible in a single column book footnote only comes in two columns(within the single text frame or seperate frame)
      Any option using script or manual.
      please refer the screenshot
      Could anyone give solution.
        • 1. Re: Footnote
          David W. Goodrich Level 3
          The first place I check for anything relating to InDesign’s limited note-handling capabilities is Peter Kahrel’s site, where he calls the kind you need “Inline footnotes.”  Peter is kind enough to credit me with publicizing a simple workaround that requires a trick but no scripting, which he further developed with a couple of scripts.  The workaround involves creating a special, indented paragraph style for the 2nd (or later) note(s) on a line, defined with zero leading.  Applying that attribute complicates fiddling with the note in layout view, making the Story Editor particularly handy.
